Old 05-05-2002, 02:34 AM
sparq's Avatar
sparq sparq is offline
AF Premium User
Send a message via AIM to sparq
Exclamation Hmmm B20 info -- still!
Alright, got a few question...
Best ECU to use with a stock CRV swap?
What about with a B16 VTEC head swap (how would the OBD work -- if its an OBD2 CRV block and OBD1 head -- just checking, is it easy?)
The Hondata system would be nice... but I dont want to spend $900 for a damn system, less of course theres money to be made by people telling you to reprogram their ECU
AF's Official Asshole
RIP AUNIE
Old 05-05-2002, 02:47 AM
kane2g kane2g is offline
Send a message via Yahoo to kane2g
Use LS one
for Vtec, there is whole bunch of options.
There is always stand alone systems.
92 fastback 240sx AKA Ess1Tree Cuz its green, and hasn't moved in months.
Old 05-05-2002, 02:54 AM
sparq's Avatar
AF Premium User
Most stand alones ive seen are pretty pricey...
So if you went with say an OBD1 B16 head -- go with an OBD1 B16 ECU?
What about the wiring of the OBD2 block... or is there nothing on the block that needs to be changed? Just curious
RIP AUNIE
Old 05-05-2002, 03:02 AM
sparq's Avatar
AF Premium User
Alright maybe I should clarify...
If you have an OBD2 block... do you need OBD2 head and OBD2 ECU?
Or... ?
RIP AUNIE
Old 05-05-2002, 04:03 AM
Si2000 Vtec Si2000 Vtec is offline
Send a message via AIM to Si2000 Vtec
Sparq, check out this link... it'll answer most of your Frank engine questions...
http://honda-tech.com/zerothread?id=174153
I might be buildin' a Frank too.. it should be interesting...
Old 05-05-2002, 04:52 AM
sparq's Avatar
AF Premium User
Its really mainly for info -- you might think its stupid to ask questions if its not goign to happen... but isnt that the whole point of learning? Thanks for the link though... good info!
RIP AUNIE
Old 05-05-2002, 07:01 PM
CivSiGuy's Avatar
CivSiGuy CivSiGuy is offline
Banned
Send a message via AIM to CivSiGuy
www.crvtec.com never hurt anyone
Old 05-06-2002, 01:12 AM
Or... ?
It depends you can do either OBD1 or OBD2
Im assuming its going into your civic which is OBD1
OBD1 would require OBD1 ECU, wiring would be really easy, and OBD1 Distributor (not 100% sure on the dist. )
OBD2 on the onther hand would require you to run some wires to the second O2 sensor and OBD2 ECU and OBD1-2 wiring plug.
Its up 2 u which way to go.
Both will need the Vtec wiring.
Hope I helped
Old 05-06-2002, 01:40 AM
sparq's Avatar
AF Premium User
Yes it does -- only tells you to pickup the Hondata ECU...
Why spend $845 for a reprogramable sysetm and then $270 on a writer for the EPROMS when the damn writer only costs $140? They must think people are stupid...
RIP AUNIE
Fuel Info Display (MPG, Range) Reset sea-doin-it Regal 3 01-06-2010 12:17 AM
Still looking for info code p1734 Haplucki5 Durango 1 09-05-2006 09:35 AM
Need Info On B20 Vtec Crank Case Breather VTEC2NRR Let's get Technical! 4 02-10-2006 10:15 PM
b20 info needed and tranny crxvato '88 - '91 Civic | CRX | Wagon | Shuttlee 1 12-17-2005 05:44 PM
b20 vtec set up info crabby760 Let's get Technical! 2 11-29-2005 01:08 PM
