Go Back   Automotive Forums Car Chat > Buick > Regal
Old 12-12-2009, 08:59 PM
sea-doin-it sea-doin-it is offline
Fuel Info Display (MPG, Range) Reset
I have a 97 Regal GS, the gas guage has not worked for years. Everything on the drivers side information display that shows you MPG, Instand MPG, Oil Life, Boost & Range has worked except the RANGE (how many miles you can drive before running out of gas).
I haved just replaced the Fuel Sender Assembly and now the gas guage works, but the RANGE still doesn't, the buttons have a reset, but it only resets the oil life, or MPG, it doesn't reset the RANGE. How can I do this?
Old 12-14-2009, 08:11 PM
irbf's Avatar
irbf irbf is offline
Re: Fuel Info Display (MPG, Range) Reset
I will have to check mine but I don't think the range resets. The range I believe is just a running calculation based on fuel available and engine output.
Old 01-05-2010, 06:24 PM
RT Jam RT Jam is offline
When you say the range doesn't work. Is it not showing a number?
65 Plymouth Belvedere
69 Dodge Super Bee
87 Dodge Ram
93 Ford Mustang 5L
00 Buick Park Avenue
Old 01-06-2010, 12:17 AM
When on the Range funtion it just says "LOW", even when I have a full tank. I read somewhere that the computer takes the average MPG for the last 25 miles and calculates with the level of fuel in the tank, how many miles you have till you run out of gas. If that was true, it would now have a number there since I have driven almost 1000 miles since replacing the fuel sending unit.
Tags
center , info , mpg , range
