Old 05-03-2002, 07:16 PM
Frostbyte Frostbyte is offline
Send a message via ICQ to Frostbyte
What do you think of Unorthodox?
I just ordered an Unorthodox Race Pulley and also a Unorthodox Full Race Adjustable Cam Sprocket. Has any had any problems with the Unorthodox Racing Parts? That Cam Gear was not cheap for the SOHC.
1989 s13 Fastback
Tein HE coil-overs
sr20det swapped!
JIC Magic Front and Rear Strut Bars
Slotted and Cross-drilled Rotors
S/S Brake Lines
Pivot Lazy eye controller
Blitz LM Intake
Blitz D1 Spec Turbo Timer
Soon to come:
Sard 550cc Injectors
Blitz Nur Spec Exhaust
Blitz Down pipe
HKS FMIC
http://www.driftmonkey.com (Part Owner)
Old 05-04-2002, 12:45 AM
SmoovSol SmoovSol is offline
Send a message via AIM to SmoovSol
My friend you will not regret it, Those parts are that expensive for a reason, unorthadox makes some good quality shit, I installed some one my brother in laws b16, not sure how much power but comparing them to pulley's like aem is like a whole new world, must be twice as light and very attractive looking. gear must be sweet too, all chrome finish? got cam? What kind?
Dont be Afraid Ta Be Different...
Old 05-04-2002, 12:51 AM
drift's Avatar
drift drift is offline
Send a message via AIM to drift
bullshit. reduced valvetrain weight wont make a noticeable difference in performance.
his motor was probably just more accepting of the cam timing adjustments.
Old 05-14-2002, 11:49 AM
Spinalfury Spinalfury is offline
Send a message via AIM to Spinalfury
ill call bullshit on you drift since i have a lightened underdrive crank pulley and i did notice a difference the engine spools up faster even though i got the cheap arospeed one you do notice a difference.
92 Civic Hatch Dx (auto)
Custom CAI ,Apc next level coilovers,
Apc Strut Tower Brace(front)
Rs Akimoto Blue silicone hose kit
Apc Clear corners, Arospeed crank pulley
Custom exhaust w/ apc muffler.
Chikara header
9.3mm Plug Wires APC
*futuremods*
55 shot Zex
possible zc swap
Old 05-14-2002, 12:26 PM
ivymike1031 ivymike1031 is offline
Send a message via AIM to ivymike1031 Send a message via Yahoo to ivymike1031
Spinalfury, an underdrive pulley is not going to have the same effect as an adjustable cam sprocket. The most important thing that an underdrive pulley does is reduce the rotational speed of the accessories, thus reducing the power that they consume (and possibly how well they perform). Any change in inertia is going to be far lower in significance than the reduction in "parasitic" power consumption.
The most important change due to the adjustable cam drive sprocket, of course, is adjustability of the cam timing. Inertia changes at the cam are about 1/4 as important as inertia changes at the crank (because of the speed ratio), and we're talking about a tiny change anyway, so I wouldn't bother mentioning how "light" the cam sprocket is. The most important factors that I can think of are: precision of adjustments, permanance of a setting (doesn't slip to a different setting while running), durability of the part, and general fit&finish of the part.
I do, however, take exception to the statement that "reduced valvetrain weight wont make a noticeable difference in performance." From the context it is clear that the author was referring to rotational mass (inertia) of the valvetrain, and from that perspective his answer is correct. In general, however, reduced valvetrain weight (if it doesn't come with a sacrifice in stiffness) will improve dynamic control of the valvetrain. This means that the engine might be able to rev higher, and that the valves will follow their intended lift profiles more accurately at the higher end of the rev range, both of which can mean better performance.
Come on fhqwhgads. I see you jockin' me. Tryin' to play like... you know me...
Thinking about getting a 240...just need to know what you think. youngmanvr4 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 64 06-28-2004 08:32 AM
Heres the deal. What you think? Koojo Audio/Security 1 11-06-2001 06:29 PM
P11GT tell me what you think. P11GT Cosmetics 21 08-02-2001 11:44 AM
Pics of My Car... Tell Me What You Think AznVirus General 8 07-29-2001 07:52 PM
