Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 08-16-2005, 09:45 PM
SoldierUnknown SoldierUnknown is offline
98 Crown Vic.. Serious Issue
I have no turn signals or hazards in my 98 Crown Vic S. Need some help, I cant find Flashers in it or at the auto store. How is the Turn Signals/Flashers setup in the Vic ???
Old 08-17-2005, 07:24 AM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: 98 Crown Vic.. Serious Issue
The turn signals and flashers are controlled by the lighting control module. First thing to test is the fuses, then the multi function (turn signal) switch. These are a common failure. They are available at parts houses. Ask for Motorcraft.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 08-17-2005, 08:38 AM
How abouts can I check and be sure its the Stalk? The LCM is that black case with the circuit boards right? That runs like 270 bucks at Ford.. If nothing else works can you just replace the flashers in it? Or does the entire LCM have to be changed. I have brake lights and headlights, just no turn signals or hazards.
Old 08-17-2005, 12:27 PM
way2old's Avatar
TOKEN HILLBILLY
That is the box. If you know which areas to repair you may be able to repair it, have never tried. Here is the easiest test in the book.
CA2 TEST HAZARD LAMP OPERATION
Turn ignition switch to OFF.
Turn hazard switch ON.
Do turn hazards flash at a normal rate?
Yes
System operating normally.
No
CHECK Circuit 10 (LG/BR) for voltage at multi-function switch. If OK, REPLACE multi-function switch; RETEST system.
Old 08-17-2005, 03:33 PM
The hazards dont work at all.. Nor the turn signals. So do I skip and check Circuit 10 to see if even the Multi Switch works?
Old 08-17-2005, 06:47 PM
way2old's Avatar
TOKEN HILLBILLY
Sounds good to me.
