Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 08-16-2005, 03:37 PM
GTPSPEED GTPSPEED is offline
BOSTONjoe98gs
will an ecu from a 96 work for a 98 both n/t
ok,in my other thread about my burned wires i told everyone that i didnt know what was wrong, but now i do the machanic said i blew the ecu and he can get me one for free from his friend who has a junk yard but its a 96 mines a 98 so question is will a ecu from a 96 work with my 98gs,thank you
2000 GRAND PRIX GTP RED 14.345 @97.8mph
ubend delete
3in jimmyC downpipe
magnaflow high flow cat
Joeflo CIA (made it myself)
free bypass mod
3.4 pulley from zzp
Gates premium belt
1 step colder plugs
zzp PCM
ss 409 xl turbo mufflers
Old 08-17-2005, 02:10 PM
-Josh-'s Avatar
-Josh- -Josh- is offline
Automotive love doctor
Send a message via AIM to -Josh-
Re: ecu question
Moved to problem diag.
Self improvement is masturbation
AF User Guidelines
What is a mippie? - click
Old 08-17-2005, 03:43 PM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
I would say with 90% certainty that it would.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 08-17-2005, 08:11 PM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
Re: ecu question
I'm not sure about the gs ecu but you could give a mitsu dealer a call and get the par number then call back and get the other one.
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
Old 08-18-2005, 10:21 PM
kjewer1 kjewer1 is offline
AF - Advisor
Re: ecu question
ECU part numbers change almost every year, even though the parts may still be interchangeable. Probably just software updates or something along those lines. So that in itself may not be terribly helpful. That being said, I know nothing about the NT ECUs.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 08-19-2005, 01:17 PM
BOSTONjoe98gs
Re: ecu question
ok good well i guess i didnt have to change it out anyway,i burned the egr wires with my intake and it died and i got no reaction from the key,but when we looked under the fuse box under the hood those wires were burned so we replaced those and now im running again so thanks guys for the help
ubend delete
3in jimmyC downpipe
free bypass mod
3.4 pulley from zzp
Gates premium belt
1 step colder plugs
zzp PCM
