Go Back   Automotive Forums Car Chat > Toyota > 4Runner/GX470
Old 08-16-2005, 01:58 PM
boodie boodie is offline
Question 22R-E cold start injector sending unit???
Hello!
My 1986 Toyota RV has a starting problem; a garage mechanic diagnosed it as a bad "cold start injector sending unit": he wired up a simple on-off switch to bypass this unit so I could get home (this was in the Winter).
Now I'd like to replace this part so it works correctly, but my local NAPA/AutoZone needs to know what it is properly called (or even where it is!)...The Toyota dealer won't even look at it (says an RV conversion isn't handled by their shop)...
It's the 22R-E 4-cyl fuel injected engine; a modified pickup truck. If I knew where it was, and could take it out and bring it to the parts store (or even BS the dealer), I could probably get it identified and a new part ordered...
Help!
Old 08-16-2005, 08:12 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: 22R-E cold start injector sending unit???
Better information can be found in the 4Runner forum for this engine. Moved
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 08-16-2005, 08:24 PM
Brian R.'s Avatar
Resident Chemist
This may be the answer if your truck looks like this:
Old 08-16-2005, 08:29 PM
Brian R.'s Avatar
Resident Chemist
Old 08-17-2005, 05:46 AM
Hmmmmm...The pic looks like the truck cab all right, but the engine itself doesn't have that big lump off to the left...Don't know what that might be, even...
But the Start Switch seems to be in the front of the engine block, one of two, on the right side (looking forward)...
I'll take a look after work and see if it's there...
Thank You!
Old 08-17-2005, 09:07 AM
Brian R.'s Avatar
Resident Chemist
Big lump to the left is the intake plenum.
Old 08-17-2005, 04:01 PM
Re: Re: 22R-E cold start injector sending unit???
..."D'Oh!!!"...
Yeah, I guess that's what the drawing is supposed to be...
OK, I found the Time Switch, at the front of the block. Looks easy to get to.
Thanks for your help!
Old 08-17-2005, 07:19 PM
Brian R.'s Avatar
Resident Chemist
You're welcome
