Old 05-03-2002, 03:16 PM
HondaSi88 HondaSi88 is offline
I need some serious tech help!!!
OK i was going to work today and not even 5min into my trip
I heard an loud KNOCKING NOISe......I pulled over popped off the valve cover and tried to adjust the valves or to see if anything was loose.......Well after that failed I started the car and the same loud knocking....Damn
I called AAA and now my car is home the first thing im gonna do is drain the oil then take the vavle cover off and check for anything odd.........
Does anyone have any ideas?
Old 05-03-2002, 03:58 PM
SleeperTeg's Avatar
SleeperTeg SleeperTeg is offline
thrown rod
dropped valve
blown rings
busted wrist pin
serious lash
water pump
low turn signal fluid
hard to tell with out actually hearing it or having a better description of the noise. hope it goes well.
btw -- you just popped your valve cover off on the side of the road?!?!
Gretchen
Off Topic Morning Crew
Old 05-03-2002, 04:15 PM
i have the oil draning out now so im gonna check everything!
thanks
Old 05-04-2002, 12:49 AM
drift's Avatar
drift drift is offline
Send a message via AIM to drift
if you dont see anything odd during a visual, it's very possible you spun a rod bearing... so no driving the car.
Old 05-05-2002, 12:37 AM
Quetzolcotl's Avatar
Quetzolcotl Quetzolcotl is offline
i hate it when my turn signal fluid runs low.
"I don't want to sound like a queer or nothin', but I think unicorns kick ass." -Trey Parker from Orgasmo
Be like Ike.
Need some serious help with my Skunk cams!!! 12secLS/vtec Let's get Technical! 1 03-21-2004 09:42 PM
Need some serious help! Blazinazn91 Integra 5 01-29-2003 09:33 PM
I need some serious TECH help!!! ShockJon Engineering/ Technical 0 05-13-2002 10:28 AM
I need some serious help/advice Oz Asia/Pacific 13 03-20-2002 08:36 AM
