Old 08-11-2005, 04:21 PM
cowboyili cowboyili is offline
supercharger pulley question
im thinking about buying a 3.4" supercharger pulley for my 98 GTP (3800). besides a K&N filter, its all stock in my engine. My question is:
what else will i have to buy for when i install the new pulley? i was told i might need to get a new PCM but I want to know for sure what i should expect. so, what else do i need to buy at the time that i purchase the pulley.
thanks!
Old 08-11-2005, 04:34 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: supercharger pulley question
thanks!
Although its recommended you really don't need a re-programmed PCM with a 3.4 SC pulley. And a GoodYear Gatorback SC belt will minimize any possible high rpm slip.
Plus you should get spark plugs that are a least one range colder in the event of knock retard (KR).
Thrasher CAI, DHP v1.0 PCM, SLP Headers,
3.25 SC pulley, CAIT GMAF, 2.5 DP/Hi-Flow CAT,
u-bend delete, 160 TS, ZZP Stage 1 TB,
TB spacer, MSD 8.5mm wires, Autolite 104s,
Goodyear Gatorback Serp. & SC Belt,
Nitto NT555R Drag Radials
Timeslip 08/12/06
AF Community Guidelines
Old 08-11-2005, 04:43 PM
WRBsGTP WRBsGTP is offline
You don't NEED any other upgrades, but other mods like a CAI and exhaust will give you better power gains. The re-programmed PCM is also a plus, but not required when swapping the pulley. You'll only need to replace some parts if you decide to install a pulley smaller than a 3.4".
