Old 08-09-2005, 06:02 PM
Simioh's Avatar
Simioh Simioh is offline
Send a message via AIM to Simioh Send a message via MSN to Simioh
timing adjuster?
What is a timing adjuster? what does it do? how does it work? thank you
Old 08-10-2005, 12:02 AM
SkylineUSA's Avatar
SkylineUSA SkylineUSA is offline
Send a message via AIM to SkylineUSA
Re: timing adjuster?
Never heard of a timing adjuster.
R32 GTR w/351w .020 forged, 8.9:1, PTK T76, Turbosmart 40 BC & 45 WG, Tial 40 BV, AFR 205s 310/245, 228/228 550/550 114 Hydro, 1.7rr, Isky RLs, 4" HKS exhaust, ARC 30x16x4 IC, 8 point cage, C2 gauges, 2 step, C4 3200 stall w/ R Manual & Hurst Ratchet shifter, 17" Panasport G7s, CSU 750 & bonnet, Vic Jr intake, 3.63 gears, Corbeau Carrera seats, Custom wide body, Bomex side skirts and rear 1/4 caps, Tommy Kaira bumper.
Old 08-10-2005, 10:45 AM
Simioh's Avatar
wow.... then im not that much of a loser hahaha heres a link so u can see it http://www.stangsuspension.com/store...?idCategory=71
Old 08-10-2005, 11:14 AM
SkylineUSA's Avatar
Looks like an adjustable timing gear for the cam, but I am not 100%. So you can advance or delay the timing events of your cam. If you do not know what you are doing you can ruin your engine.
Old 08-10-2005, 11:57 AM
GTStang's Avatar
GTStang GTStang is offline
Stang Guy
Send a message via AIM to GTStang
The Ford Mod motors have an EDIS igniton that uses a 36-1 trigger wheel with sensor. The sensor is mounted a certain amount of degrees from the missing tooth on the wheel. By moving the sensor one way or the other you can increase or decrease base timing just like the good old distributor days. These timing adjuster just helps you move the sensor properly.
R.I.P. Hypsi- Andy your one of the best people I ever had the priviledge to know. AF and the world
has lost one of the truly wonderful people...
Old 08-10-2005, 01:16 PM
SkylineUSA's Avatar
Thanks,
So its like my Crank angle sensor on my Skyline, gotcha.
Old 08-10-2005, 04:49 PM
351wStang's Avatar
351wStang 351wStang is offline
Work sort of like a pulse ring for anti lock brakes?
1969 Cougar
357w & TKO - 475hp
Old 08-10-2005, 07:00 PM
GTStang's Avatar
Stang Guy
Re: Re: timing adjuster?
For the sake of KISS...... yea.
