Old 04-30-2002, 01:13 AM
ck79 ck79 is offline
Question zc block
This 88 crx has a 1.6 zc block in it. With an SI Head and the original 1.5L
intake manifold and dual point inj. throtle body ( I bought the car as is)
Car needs new head... can I use a DOHC Vtec head or is the ZC
block compatible with DOHC only ?
Can I use USDM head or do I have to locate a JDM head?
I am also upgrading the manifold and throtle body to match whatever
head I use.
Old 06-14-2002, 07:20 AM
rob_hoody rob_hoody is offline
Post
now is that the sohc zc? if so and its DPFI youve got some work to do. no there isnt a dual overhead vtec head for that motor. but if you really want vtec you can put the sohc d16y6 or d16z6 head on it. remember the zc is a d series motor. if you get a zc head you can only use a zc intake. if you go for the d16y or z you can use anything from a sohc 1.6 from 88 to present. and the exhaust manifold are interchangeble except on the zc it needs to be ported.
Definition of big block vs. small block Musclecarclub Engineering/ Technical 79 01-19-2016 09:38 AM
Long block and Short block 4thgenlude Engineering/ Technical 1 04-06-2003 09:03 PM
ls block and gsr block? liquid8 Engineering/ Technical 39 04-09-2002 01:57 AM
BiG block, Small Block LeGoLaS Engineering/ Technical 4 02-05-2002 04:44 PM
Small Block vs. Big Block Racer 20 Car Comparisons 13 06-07-2001 11:58 PM
