Old 02-03-2002, 11:46 PM
LeGoLaS LeGoLaS is offline
BiG block, Small Block
What makes the cars engine be defined as having a big block or a small block.
what is the median to seperate the 2.
Old 02-04-2002, 03:48 AM
GTStang's Avatar
GTStang GTStang is offline
Stang Guy
Send a message via AIM to GTStang
The declaration of block size is really based on the Block itself. But basically for Chevy 350 and under is a small block, Ford 351 and under is small block. There are some exceptions, I know Ford so maybe some1 else can tell u chevys.
Ford 351 Windsor small block, 351Cleveland and 351m/400 both big blocks
Old 02-04-2002, 11:48 AM
TheMan5952 TheMan5952 is offline
Volvo Guy
Send a message via AIM to TheMan5952
In Mopar a 383 can be a small block or a big block, they made both. If an engine has wide valve covers, it's a big block, if they are narrow it is a small block. Chevy made a 400 small block for a little bit.
-Joe- '02 Volvo S60 T5
Sold!1993 volvo 850
Intake, Exhaust, Springs, Shock, I.C.E.
Old 02-04-2002, 03:18 PM
Hudson Hudson is offline
Old Mod
As you can tell from the above posts, "small block" and "big block" is just the name give to differentiate the (usually) two different engines made by a manufacturer. The two different engines (big and small) have different exterior dimensions.
Old 02-05-2002, 04:44 PM
fritz_269's Avatar
fritz_269 fritz_269 is offline
There was recently a thread about this (among other things) in the Honda/Acura Technical forum:
http://www.automotiveforums.com/vbulletin/t23140.html
Definition of big block vs. small block Musclecarclub Engineering/ Technical 79 01-19-2016 09:38 AM
big or small block ledi Mustang Talk 2 08-01-2005 09:33 AM
Big Block or Small Block? sky73 Nova 5 03-09-2005 03:32 PM
small blocks and big blocks? whyidontknow Engineering/ Technical 7 07-01-2004 04:04 PM
Small Block vs. Big Block Racer 20 Car Comparisons 13 06-07-2001 11:58 PM
