Old 07-29-2005, 07:32 PM
x_skaven_x x_skaven_x is offline
Send a message via MSN to x_skaven_x Send a message via Yahoo to x_skaven_x
Urgent! Need Help. Pic Provided
Hey, I made a post yesterday about this problem but i made a new one cause i found the problem but not sure what it is lol. I have a picture of it. Theres a bracket and a steel pipe going from side to side. Its only broken on one side. What is it and what does it do? I circled the bracket im talking about in ms-paint. its a 92 GP LE by the way.
http://photobucket.com/albums/v460/s...rproblem12.jpg
Old 07-29-2005, 07:59 PM
Re: Urgent! Need Help. Pic Provided
no one knows what that bracket and pipe is for?
Old 07-29-2005, 08:11 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: Re: Urgent! Need Help. Pic Provided
We've got em on later model Grand Prixs too. It looks like your rear anti-sway bar and the left side mounting bracket. At the bottom of the bracket is the rubber bushing which holds the sway bar.
Thrasher CAI, DHP v1.0 PCM,
3.25 SC pulley, CAIT GMAF, Hi-Flow CAT,
u-bend delete, 160 TS, ZZP Stage 1 TB,
TB spacer, MSD 8.5mm wires, Autolite 104s,
Goodyear Gatorback Serp. & SC Belt,
Nitto NT555R Drag Radials
Timeslip 08/12/06
AF Community Guidelines
Old 07-29-2005, 08:12 PM
no the bracket is broken .. is this a big fix?
Old 07-29-2005, 08:13 PM
is it dangerous to drive it with that bracket broken
Old 07-29-2005, 08:18 PM
i just managed to find it in my chiltons book..its my rear stabilizer shaft and a bracket in that picture....is having that bracket dangerous?
Old 07-29-2005, 08:21 PM
BNaylor's Avatar
I wouldn't say its dangerous to drive with it broken but you never know. I worked with a guy that had a '91 - '92 Regal a few months back with a similar problem and all he complained about it was noisy. The rust out looks pretty bad and its looks like it will need welding. You must get a lot of rust up North.
Timeslip 08/12/06
Old 07-29-2005, 08:23 PM
so it could just be welded back? I have a buddy whos a professional welder i guess you can call him lol..works in a metal fab shop
Old 07-29-2005, 08:30 PM
BNaylor's Avatar
I'm quite sure it can be welded but it depends on how much metal has been eaten away by the rust. I'd take it to your buddy and see what he says about it. Good luck!
Timeslip 08/12/06
Old 07-29-2005, 10:26 PM
yea i spoke to that welder friend of mine..hes also pretty good mechanic but I didn't know if the car was safe to drive and what not so i posted here. He said i should just buy a new "Rear Stabilzer Bar Bracket"...welding would work for a while but wont last long due to the amount of rust on the part. So I think im going to go down to UAP/NAPA and order a new part. Should I be able to put this on myself?
Old 07-30-2005, 12:44 AM
dmasjz45 dmasjz45 is offline
shouldnt be too hard...that rust is pretty bad, id take a wire brush and clean what you can on the underside and then brush on some dexron3...works nice as a coating to prevent rust
Old 07-30-2005, 02:36 AM
BNaylor's Avatar
The parts you'll need are:
Left Stabilizer Link GM Part # 10259660 GM List Price $13.45 U.S.
Left Link Bracket GM Part #10409334 GM List Price $29.32 U.S.
The link bracket bracket is the part that mounts to the chassis undercarriage. The stabilizer link is the part that holds the stabilizer (anti-sway) bar.
Timeslip 08/12/06
Old 07-30-2005, 03:17 AM
may i ask where you found the part number and price?
Old 07-30-2005, 03:34 AM
BNaylor's Avatar
I have a Mitchell parts listing covering the Grand Prix and Regal going back to the early nineties models and up to 2003. Its the same guides that body shops use.
Timeslip 08/12/06
Old 07-30-2005, 12:23 PM
thanks for all your help man...im going down to order the parts today.
