Old 07-29-2005, 05:59 PM
ttran203 ttran203 is offline
Help!!! No sound from speakers
I have a pioneer HU w/ a 50watts X 4 internal amp. I was driving one day and then the speakers just cut out on me. I checked all my wiring and its all fine, but then I realized that I might have blown my output IC or internal amp. So, i ordered a new one and soldered it on. still i got no sound from the speakers. Everything other than that works fine. Can anyone tell me what is wrong?
Old 07-29-2005, 06:09 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
it would be nearly impossible to know without seeing it in person
Old 07-30-2005, 12:06 AM
DemonaL DemonaL is offline
Send a message via AIM to DemonaL
Re: Help!!! No sound from speakers
fuse?
150 amp alternator - bigger comming soon
3 batteries Deep Cycle
Alpine Type X's 12'' x 2 - better comming soon
JL Audio 1000/1 x 2
JL Audio 300/2 x 2
MB Quart 51/4's and 6x9's
Alpine CDA-9831 - iva-d901 soon
0/1 Guage Wire
Viper 791XV
Old 07-30-2005, 07:58 PM
Can you tell me some major components of the HU that can cause my problem. Or can you list some possible solutions to my problem? Thanks for all the help
Old 07-30-2005, 07:59 PM
Re: Re: Help!!! No sound from speakers
Originally Posted by DemonaL
fuse?
no, i checked the fuse in the back of the HU and its fine. Can any other fuse cause this problem?
Old 07-30-2005, 09:44 PM
Audio Guy
if the radio AND the CD player do not have any sound, than it won't be either of those. If you are using only the internal amp, then it isn't something like the auto turn-on wire. If the unit looks liike it's playing then it's not likely to be a fuse - although sometimes the constant 12V fuse can blow and it looks like the headunit is playing when it's really not. If none of that is problem then it must be somewhere in the internal amp section.
Old 08-03-2005, 04:00 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
is there any possable way for you to hook it up to an amp using the rca's? If you have sound from rca's, and not the outputs, then its more than likely the output chip. Did you replace it with the exact same one? I believe pioneer uses mainly the PAL007A Mosfet. If you serach around you can find them pretty reasonable. Um, usually when an ouput IC chip blows, it fries something else on the cirsuit board. Look about for burning or melted capacitors. And smell, use that nose. Smell for burnt components. Like I said if you get sound from the rca's, and not outputs, then its the output IC, but if no sound from either, its something else, and probably isnt worth your trouble. Good luck.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 08-10-2005, 05:00 AM
dewmiester dewmiester is offline
when i installed my 6" front speakers, there was no hole for them in the door, i cut out a hole, but the metal of the door was touching both the + and - on one of the speakes, which stopped them from working..this may or my not help, but its here for the taking
Old 08-10-2005, 07:23 AM
L|_|da L|_|da is offline
Send a message via AIM to L|_|da
have you tried swithcing out your speakers? it might possibly be them, or you shorted out the outputs cuz they were touching metal which could have completed thew connection right there
