Old 07-27-2005, 11:37 PM
bl1tzk1213g bl1tzk1213g is offline
6bolt with 2g ECU
i talked to a mechanic earlier. He told me i could just drop in a 6bolt without changing the harness
1997 Mitsubishi Eclipse GS-T 5spd stock ?
Tsudo 3" catback
Bomz Intake
HKS SSQV BOV
bcs mod and a useless boost gauge
Old 07-28-2005, 12:40 AM
kjewer1 kjewer1 is offline
AF - Advisor
Re: 6bolt with 2g ECU
Thanks for the tip! Or was that supposed to be a question? Either way, Thats correct. You will have to swap over some of the sensors, but its all easy work. The only rewiring will be for the 1g CAS. Which then in turn causes the dreaded random misfire CELs. The baro wire mod is the poor mans fix, while DSMlink will do the job correctly. www.magnusmotorsports.com and www.roadraceengineering.com have tons of info. The swap is very common and very well documented.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 07-28-2005, 02:55 AM
Whathits14 Whathits14 is offline
Women < DSMlink
naaa...not really but its damn close
Need a GOOD 6-bolt engine?
http://www.totaljdm.com/?id=19334
'95 Talon Tsi
EVO III GT, supporting mods, not running
Brand new never opened, walbro 190LPH fuel pump for a 2g $65 shipped.
Old 07-28-2005, 04:42 AM
oh kool. So if i just get a 6bolt tomorrow (yea right) and just switch some sensors, and probably grab a handy DSMlink im all set right? no need for overhauling? :o
Tsudo 3" catback
Bomz Intake
HKS SSQV BOV
Old 07-28-2005, 07:46 AM
AF - Advisor
Overhaul on the motor? That all depends on the condition of the motor you buy.
Kevin Jewer
Old 07-28-2005, 09:10 AM
-Josh-'s Avatar
-Josh- -Josh- is offline
Automotive love doctor
Send a message via AIM to -Josh-
Anytime you buy a used engine you should send it to the machine shop to have it looked at.
Self improvement is masturbation
AF User Guidelines
What is a mippie? - click
Old 07-28-2005, 01:20 PM
yea i kno that but theres nothing else needed to do but switch the sensors and do some drilling for the mouting/water pump right?
Tsudo 3" catback
Bomz Intake
HKS SSQV BOV
Old 07-28-2005, 07:52 PM
AF - Advisor
I gave you the links above. This is a well documented process. Please do the research. Its not something that is easy enough to sum up in a few words, and I'm not going to write a novel about something that is already been covered 1000 times. The magnus site even has a parts list that is specific to the 95-96 and 97-99s. It doesnt get any better. Happy reading
Kevin Jewer
