Old 07-25-2005, 12:46 PM
Jcrane88 Jcrane88 is offline
Send a message via AIM to Jcrane88
2.8 owners HELP
i almost got everything swapped over ( i got a fuel injected 2.8 and i'm putting my carberated stuff on) on the right side valve cover ( passenger side) what comes out of the hole on the valve cover?? and where does it go? the other side is the pcv valve and oil fill.......
thanks
John
1984 Camaro 5.7L 350
700R4
Holley 650 Cfm
Edelbrock Performer Intake-Manifold
Crane Cams Duration @ .050": 204/214 Lift:420/442
Summit HEI Distributor
Hedman Shorty Headers
Hedman Y-pipe
Dynomax Turbo cat-back
NOS Decal
VTEC Decal
Old 07-25-2005, 01:02 PM
Mr. Luos's Avatar
Mr. Luos Mr. Luos is offline
Firebird Guy
Re: 2.8 owners HELP
Breather??
Smog pump?
1999 Pontiac Trans Am WS.6 #1747
Stock'ish'
Old 07-25-2005, 01:11 PM
92zcamaroperson's Avatar
92zcamaroperson 92zcamaroperson is offline
Re: 2.8 owners HELP
breather.
Old 07-25-2005, 01:15 PM
it's a hose that goes there right? where does that hose run to?
700R4
Holley 650 Cfm
Hedman Y-pipe
NOS Decal
VTEC Decal
Old 07-25-2005, 01:50 PM
Re: 2.8 owners HELP
If you go to a parts store they should sell breathers there. They look like small air filters. Originally a hose would run from the valve cover to the air intake housing some where. You can just put one of the little breather filters on it and you should be fine. They are like ten dollars or something.
Old 07-25-2005, 02:10 PM
i oughta go get a diagram for all the hoses running everywhere.....i took a video with my digi camera before i tore my engine apart but in the video it was already off
700R4
Holley 650 Cfm
Hedman Y-pipe
NOS Decal
VTEC Decal
Old 07-26-2005, 01:23 AM
blindeyed's Avatar
blindeyed blindeyed is offline
eBay aDdict™
Send a message via AIM to blindeyed
Re: 2.8 owners HELP
It's an intake hose/tube that goes there that should connect to the back of your intake. It's a weird setup that GM made, but's it's basically a breather. Kind of like the tube that runs from your intake elbow to your left valve cover.
- Jason
1995 Pontiac Firebird
User Guidelines | VB Codes Explained | AF Merchandise
"Each of us, is in the scheme of things, insignificant.
But millions of insignificant people, doing a tiny bit,
can add up to be a very significant force."
Old 07-26-2005, 01:31 AM
blindeyed's Avatar
eBay aDdict™
Re: 2.8 owners HELP
Oh wait, your talking about the passenger side. My bad.
Yours should have been set up the same way as mine, with an intake tube running from the intake elbow to the passenger side valve cover. You could do something like this. It's what I did to my valve cover. I just got my intake tube an used my grinder to shorten it. Then popped one of those APC valve cover breathers on it ($10). I had to use the tube as an extension because there was no room for it to sit on top of the valve cover. There may be room for you though, but my egr (not pictured) sits right in the way.
- Jason
