Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 07-24-2005, 11:59 PM
C_Lo C_Lo is offline
Angry Parking Break Stuck!!!!!!! Can anyone help me
I have a 93 CV and the light for parking break on the dash was flashing on and off for two days. I decided to push the press and depress the parking brake to see if that would eliminate the problem. When I depressed the brake nothing happened, the parking break remained engaged and now after numerous attempts the parking break refuses to disengage. Can anyone help me????????, thanks.
Old 07-25-2005, 05:06 AM
KimMG KimMG is offline
AF - Advisor
Re: Parking Break Stuck!!!!!!! Can anyone help me
Does your car roll when you release the brake?
Did you check the fluid level? Brake light on dash may come on for a number of reasons, ie. low fluid, bad master cylinder, parking brake on, worn brake pads if you have wear sensors.
Old 07-25-2005, 09:17 AM
Question
The parking brake is stuck, it refuses to release. Is there a way to disengage it without using the normal release pad?
Old 07-25-2005, 05:27 PM
found a Solution
I just yanked on the parking brake cable benieth the car and it disengaged.
Old 07-26-2005, 06:44 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
ither the front cable is hanging up or the actuators are rusted together on the rear backing plate. Vics are bad about the front cable getting cut where it goes through the body behind the plastic inner fender.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 07-27-2005, 08:13 AM
fbi-interceptor fbi-interceptor is offline
Send a message via Yahoo to fbi-interceptor
my 93 disengages when i put into drive.
[/IMG]
