Some Updated Bodywork Pics
Ok for some of you a.k.a. HiFlow this is long overdue. But After many distractions and set-backs I finally am making progress on the Stang again. So I have a few new pics:
First these are just a couple pics of what it looked like last June. ![]() ![]() ![]() Ok now the new.... please excuse the quality, bad lighting, and the dirty glass. I was gonna wait till tom when I roll it out into the sunlight but some people couldn't wait. So I figured I might as well show them to you guys too. And that spot that looks like faded paint on the front quarters are actually stripes using Ice Pearl. Hopefully tom I will roll it out in the sun and you will get to see what the stripes really look like cause the pop like a bastard in the sunlight. Anyway I still have some more parts to paint and I need to sand the clear and put on some flo-coats of clear and then powerbuff. So a few more weeks and I may finally have the car back on the road.
R.I.P. Hypsi- Andy your one of the best people I ever had the priviledge to know. AF and the world has lost one of the truly wonderful people...
Re: Some Updated Bodywork Pics
the paint looks nice
That is an awesome color. What blue is that? Very nice choice.
R32 GTR w/351w .020 forged, 8.9:1, PTK T76, Turbosmart 40 BC & 45 WG, Tial 40 BV, AFR 205s 310/245, 228/228 550/550 114 Hydro, 1.7rr, Isky RLs, 4" HKS exhaust, ARC 30x16x4 IC, 8 point cage, C2 gauges, 2 step, C4 3200 stall w/ R Manual & Hurst Ratchet shifter, 17" Panasport G7s, CSU 750 & bonnet, Vic Jr intake, 3.63 gears, Corbeau Carrera seats, Custom wide body, Bomex side skirts and rear 1/4 caps, Tommy Kaira bumper. |
Good looking car.
the car looks great. i really like the color, what is it called?
87 5.0 5 spd T-Tops - mass air conversion 9AL, msd distributer, coil, fms 9mm wires, bbk ceramic coated long tubes, bbk h pipe, 3" flowmaster catback, 190 lph fuel pump, 24 psi injectors, 70mm cobra meter, bbk AFPR, bbk fender kit with k&n filter, 12* base timing, flex fan, 3 row aluminum radiator, 6 piece headlight kit w/ clear corners, silver ponys, stormin normin cowl hood, saleen wing, and recently a new heater core
Here is some more pics I took today after I rolled it outside. Car still def needs to be sanded and re-cleared but it's definetly got potential.
You can kinda see the stripes and the ffect a little in this picture. Start to see it a little more: Still can seem to get the full effect with a Camera but you get the idea. Picture of the stripe going down the side can see some of the orange peel I need to sand out. Just the back again.
I love watching progress pics of complete body work / paint jobs. People think it's so hard to paint a car, when it's mostly just being patient, taking your time and making sure your prep is right.
Did you color sand between coats, then on your final coat and polish? I see you have orange peel so I'm assuming not.
'89 Mustang GT - Edelbrock intake, 75 MM TB, 77 MM MAF, MAC longtube headers, MAC Pro-chamber w/ 2 chamber flowmaster exhaust. Runs 13.5 in the 1/4 spinning like a mofo. '91 Toyota MR-2 - JDM 3SGTE, 50 trim t3/t4, LSD, SPEC clutch, Apexi'i CAI, 12.4 @ 15 psi, high 11's on the 50 shot. '97 Ford Explorer Eddie Bauer '78 Jeep CJ-5 - 401 C.I.D. O||||O '01 Yamaha YZF600R - Full D&D carbon fiber exhaust, Cam, Factory pro shift kit, front sprocket and miscellaneous other goodies. |
Now that is sharp!
I like it alot can't wait to see her with bumpers and all |
Re: Re: Some Updated Bodywork Pics
The basecoat needs to be cleared within 24 hours of spraying or you need to sand respray more color and then clear. I had to be somewhere so I threw one real quick but pretty wet coat of clear on just so I didn't have to re basecoat, that is what your looking at why you see so much orange peel. I was planning anyway to re-clear with some flo-coats to get rid of the lines cause from taping off the stripes. To do this I need to wetsand and re-clear the car anyway so it was not a big deal. So next clear there will be almost no orange peel cause I'm gonna take my time but I will wetsand with 2000grit and powerbuff anyway just to get that always wet look.
You color sand your primer with 800? The finest I go is 320 on primer, because your base needs something to hold on too. Plus you're still going to have orange peel that will need to be addressed when you wet sand the clear.
For the clear on my cars I block wet sand with 800 and work to 2500. I guess there is more than one way to skin a cat. By the way, you never sand on a base coat, or atleast the paint I shoot, unless like GT mentioned sand and re-spray.
As far as the physical adehsion of the paint yes you don't want too fine cause the scratches actually give it it's pyhsical adehision. But that is much more of a problem with spraying on top of a clearcoat than it is a base. I always use an expoxy primer usually PPG DP which bases likes to stick to a lot better chemically than etching and other types of primer so the pyhsical adhesion is not as needed with this set-up. As far as orange peel in the clear I have learned to spray very wet to the point of almost running it(Trick taught to me by a very talented painter). This helps to eliminate almost all orange peel. Yes there will still be some you can't spray clear without some orange peel. But what I end up with is so little that wetsanding wit just 2000grit then powerbuffing takes out all of it. This is about the 5th full car I have painted and more fiberglass hoods, bumpers, spoilers and bumpers than I care to count. This is the method I have developed in my situation that has proven to work the best. It's not the only way... just the way I proven to work for me consistently. Also color sanding is more of something that was done back in the day of laquer paints. Some guys still do it and have great sucess. I find it totally not needed with modern paints. But like I said there is no right way it's whatever way gets you the best results.
Looking good Bobby, and it's about damn time! I started a little more body work on my GT and threw some primer on the front clip. I t hink I need some lessons from you though when I go to paint.
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex -1999 Ford F150 |
Re: Re: Re: Some Updated Bodywork Pics
And yes, you have to spray almost to the point of were its going to run to keep the orange peel at bay. If you have had no problems with the paint adhesion, I might just go up to 500 on the car that I am doing right now adn see if there is a difference in the finished product. Thanks for the input. When I was in the states, PPG was my weapon of choice. Here I have to use some stuff from Holland, its not bad, but if I had a choice I would use PPG.
Re: Re: Re: Re: Some Updated Bodywork Pics
