Go Back   Automotive Forums Car Chat > Buick > Century
Old 07-21-2005, 06:15 PM
gabby_g gabby_g is offline
Engine power problem
Hi all,
Just got my 2000 Buick Century from the dealer...
When I am driving the car, and push the gas pedal to accelerate strongly, the engine starts running up speed, and then starts to cough, and the cars losses power (This is normal on neutral...??)
If I push the pedal gently, the car will accelerate normally and run normally.
Help ?
Thanks
Gabby
Old 07-22-2005, 10:06 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: Engine power problem
Originally Posted by gabby_g
Hi all,
Help ?
Thanks
Gabby
Did you just get the car back from service at the dealer? How many miles are on your Century?
In neutral or park if you rev the engine up it will cut off at around 4000 rpm because of the rev limiter in the PCM computer but this is normal. The cut out or losing power when moving and at WOT is not normal.
Timeslip 08/12/06
AF Community Guidelines
Old 07-22-2005, 09:59 PM
Hi...
The Car has 59000 miles on it..
I know about the REV limiter, the problem that it happens during drive as well...
Gabby
Old 07-23-2005, 03:11 PM
BNaylor's Avatar
Hi...
Gabby
The only thing I can suggest is a basic tune up if it already hasn't been done. Fuel filter, air filter, spark plugs and wires.
What exactly is the car doing? Does it feel like a misfire or just cutouts at a certain rpm? Other things that could be checked is to make sure there is 45 - 55 psi of fuel pressure at the fuel injector rails and have your coil packs tested. Also you could clean the MAF sensor. Good luck!
Timeslip 08/12/06
