Old 07-20-2005, 03:12 PM
BlackGT2000's Avatar
BlackGT2000 BlackGT2000 is offline
Quick question on tires
Right now I have 245/45 17s, I plan on ordering some new tires and I wanted to go a little wider. Do I just order a larger width with no change to height? For example 255/45 17. Also, I know the stock gatorbacks have pretty bad ratings. I have driven other cars with BFGs but not sure which kind. Does anyone have any recomendations on a good tire for under $140 a piece.
Old 07-20-2005, 03:38 PM
ScottyB1 ScottyB1 is offline
In metric sizing, the height is a function of the width. So, if you change the width, the height will also change. For instance, you said you are running a 245/45/17. Your tire height will be specified by 45% of 245. If you increase to 255, obviously 45% of 255 is greater than 45% of 245.
So plan accordingly.
sb
sb
2005 Nissan Xterra
1991 Mustang 5.0 LX Conv.
2 rugrats
1 dog named "Blue"
Old 07-20-2005, 11:57 PM
2crunk's Avatar
2crunk 2crunk is offline
Re: Quick question on tires
Check out www.tirerack.com they are pretty reasonable on pricing and have a wide selection of sizes and brands.
Check out more pics and info on my Stang at: http://www.cardomain.com/profile/2crunk
Rest In Peace Hypsi87, you'll be missed.
Old 07-21-2005, 12:08 AM
SkylineUSA's Avatar
SkylineUSA SkylineUSA is offline
Send a message via AIM to SkylineUSA
go to www.4lo.com they have a bunch of calculators you can use.
R32 GTR w/351w .020 forged, 8.9:1, PTK T76, Turbosmart 40 BC & 45 WG, Tial 40 BV, AFR 205s 310/245, 228/228 550/550 114 Hydro, 1.7rr, Isky RLs, 4" HKS exhaust, ARC 30x16x4 IC, 8 point cage, C2 gauges, 2 step, C4 3200 stall w/ R Manual & Hurst Ratchet shifter, 17" Panasport G7s, CSU 750 & bonnet, Vic Jr intake, 3.63 gears, Corbeau Carrera seats, Custom wide body, Bomex side skirts and rear 1/4 caps, Tommy Kaira bumper.
Old 07-21-2005, 01:20 PM
TheStang00's Avatar
TheStang00 TheStang00 is offline
well i dont know to much about the tires, but i liked the continental touring tires a lot more than the ones i have now i can tell u that
Old 07-21-2005, 03:20 PM
SMOKINGIROC SMOKINGIROC is offline
go with bridgestone potenzas, i've got those and their bad ass.
1989 IROC,NEW GM 350 H.O VORTEC ENGINE, HI-FLOW VORTEC TPI SYSTEM, SLP CAI, SLP HEADERS, 3" FLOWMASTER CAT-BACK, PORT & POLISHED HEADS, CORVETTE SERVO, SHIFT KIT, B&M MEGA SHIFTER, HOTCHKIS SUSPENSION,
Old 07-22-2005, 02:11 AM
GTStang's Avatar
GTStang GTStang is offline
Stang Guy
Send a message via AIM to GTStang
sb
What he said but to simplfy it a lil.....
The second number is aspect ratio wit is a function of width. So if the width increased but and the aspect ratio stayed the same your tire height would increase....
So to keep the same height as now and keep your speedo readings correct etc.., you may have to change aspect ratio depending on how wide you go. Also note this often will be just finding numbers close but not exact there is a lot of close enough is ok when dealing wit tires and speedo readings.
Old 07-22-2005, 12:37 PM
Awesome thanks guys, so basically its going to end up being something like 255/40 just as an example.
