Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Audio and Videos
Old 07-16-2005, 01:11 PM
BoNkA10 BoNkA10 is offline
Send a message via AIM to BoNkA10
Sound deadening
I just got all my audio stuff put into my car and my subwoofer is completely destroying my hatchback. There is WAY too much rattling and I'm not even sure exactly what spots it's coming from. I was wondering if anyone has had this problem and fixed it or knows a good way to. I doubt throwing sound deadening material in the trunk will help much.
1998 Eclipse GS
Old 07-17-2005, 03:41 PM
cficare68's Avatar
cficare68 cficare68 is offline
Re: Sound deadening
Get some dynomat it helps
2006 Mitsubishi Eclipse GT Debagged, 18" MKW Rims, 5% Tint, Ralliart Eyelids, Outlaw Racing IM and TB Spacers, Ingals "Stiffy", Energy Suspension Polyurethane Motor Mounts, Tanabe Lower Tie/Strut Bars, Progress Rear/Eibach Front Sway Bar, D2 Racing Lowering Springs, RRE Headers and Axelback, AEM CAI w/ Bypass, 12000k HID Heads, 3000k HID Fogs, Sunroof Wind Visor, Drilled/Slotted Front/Rear Rotors, and Ceramic Brake Pads.
Old 07-17-2005, 11:23 PM
Re: Sound deadening
I assume I'd have to rip off all the paneling, put the dynamat, then put the paneling back on?
1998 Eclipse GS
Old 07-18-2005, 04:09 AM
fiberglasscivic's Avatar
fiberglasscivic fiberglasscivic is offline
Send a message via AIM to fiberglasscivic Send a message via Yahoo to fiberglasscivic
Re: Sound deadening
That would be correct. Try going over all your nuts and bolts on the hatch and anything associated with your hatch area and re-tighten everything. The sound deadening material will help out lots.
AF COMMUNITY GUIDELINES
Old 07-18-2005, 08:47 AM
Re: Sound deadening
The only problem I've seen so far is it looks like there's 2 screws (possibly) missing that were holding the paneling on the actual hatchback. It's the closest piece to the rear of the car and has 1 spot on each side part way up the hatch, where it overlaps the other peice of paneling, for a screw, bolt, or something else that may just be jammed into the hole to hold the paneling better. Whatever was there is no longer there. I assume it was there before I had the audio and alarm installed and they ripped that panel off for the alarm (maybe) and lost whatever went in there.
I did find a good amount of screws on my floor when I got it back, but I have no idea what they're for. None of them seem to fit what I'm talking about though, so I'm pretty lost as to what was in there.
1998 Eclipse GS
Old 07-19-2005, 04:52 PM
Eagalicious's Avatar
Eagalicious Eagalicious is offline
The two holes you are talking about inside the hatch. Those are screw holes. There are two black coarse screws that go there. Take the screw that is at the end by the latch that lifts the spare wheel cover and remove the panel. They probably did not place all the retaining clips back in when the put the cover back on. The screws for the hatch are the same screws from the console or door panel screws. just take one out and go to Home depot or ace hardware and ask for a match.
Good luck!!!
1997 Eagle Talon Tsi AWD
K&N FIPK
HKS SSQV BoV (coming this weekend)
HKS Recirculation kit (coming this weekend)
The rest is stock but not for LONG!!
