Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > Maintenance
Maintenance problems, fixes.
Old 04-25-2002, 03:42 PM
lee533 lee533 is offline
Send a message via AIM to lee533
auto tranny fluid change
when should the auto trans fluid be changed?
Old 04-26-2002, 09:27 AM
jayntguru jayntguru is offline
Every 30K miles.
-Jay
1993.5 G20
http://www.nx2k.com/G20/
11 second GSX
http://www.nx2k.com/eclipse/
Old 04-26-2002, 01:39 PM
lloyd_nickens's Avatar
lloyd_nickens lloyd_nickens is offline
with what type (number) fluid. (basically is there a special nissan oil of is the "good enough for ford" stuff okay?)
"God Bless BASS, What Would We Do Without It?"
"If You Can Breathe, Turn The Music Up."
Old 04-28-2002, 05:12 AM
Yahnozha Yahnozha is offline
Send a message via Yahoo to Yahnozha
Use GL-4 in the tranny, on the se-r mailing list several people have been running into probablems with GL-5 tranny fluid. Something in the GL-5 is known to cause corrosion to some of the brass/bronze parts in the tranny
P@ - www.customsteel.com
Red 99 G20(t) / UR 2 piece / JWT POP / HS CAI / WW Lip / HS Header / Greddy Evo / S3 cams
Old 04-29-2002, 01:28 AM
paradyme paradyme is offline
Thumbs up
I have used Mobil 1 ATF for the last 2yrs, No Problems at all. A little pricey, but worth the purchase. I use 5 quarts and change it myself.
:flash:
paradyme
95'G20t/AUTO/BLK
STILLEN HEADER/INTAKE/JWT/ECU/S3 CAMS/P11 99 G20 RIMS/
VIPER SECURITY/w/ REMOTE START/ ALPINE AUDIO
Old 04-29-2002, 09:05 AM
tranny fluiid all or some?
If you change it yourself with only 5 quarts you must not be removing all the fluid? a simple drain and fill will leave several quarts of old fluid still in the tranny
Old 05-01-2002, 02:16 AM
Lightbulb
Yeah,,,The torque converter holds a few quarts, so unless you are dropping the pan for some reason like changing the filter 5 quarts is all you need. I had the pan dropped, replaced the gasket and the filter cleaned, the 1st time I made the change from standard fluid to synthetic.
:flash:
paradyme
95'G20t/AUTO/BLK
Old 05-09-2002, 12:17 PM
rickp rickp is offline
Does the FSM specify the correct fluid change method?
Regarding auto tranny fluid changes. Huney1 General Discussion 0 10-05-2007 05:00 AM
changing auto tranny fluid, good idea or not? wildlysmiley Rodeo | Passport | MU 24 04-17-2006 10:28 AM
Auto tranny fluid change burl Tribute 1 07-14-2005 12:29 AM
Changing AUTO tranny fluid 2000 Jetta VR6? Jetta_Y2K '97 - '03 6 03-09-2005 06:18 PM
Changing Auto Tranny fluid and filter-do I need special tool? mjrodney C/K 3 12-24-2003 11:56 AM
