Old 12-17-2003, 03:43 AM
mjrodney mjrodney is offline
Proud AF Supporter
Changing Auto Tranny fluid and filter-do I need special tool?
The repair manual for my 99 Silverado tells me I need to use a special "alignment pin", GM p/n J36850, in order to install the Automatic Transmission Filter Seal after a filter/fluid change. 4L60-E tranny.
Do I really need this tool?
Also, the manual tells me to lube this seal with GM p/n J36850 and to seal the pan plug using GM p/n 12346004. What are these products and is there a generic equivalent?
Thanks for the help on this.
Old 12-17-2003, 11:53 AM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
Re: Changing Auto Tranny fluid and filter-do I need special tool?
When doing a trans service, the filter seal will stay in the trans housing when you pull the filter out. Using a little creativity and some patience, you can remove the seal with out damaging the trans housing...if you don't feel confident, inspect the filter seal..if it looks OK, leave it alone and slide the new filter inside the seal (although this is not the best way of doing things and not recommended...sometimes it is better to leave the old seal alone)
If you want to install the new seal. you can use a socket the same size as the seal to drive the new seal into place (once again not the best way, but sometimes you have to make due)
Lube the seal with trans fluid.
On the drain plug bolt, use medium strenght loc-tite (the blue stuff)
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
Old 12-17-2003, 12:15 PM
Proud AF Supporter
Thanks for the reply, GMMerlin.
From your reply, I must assume the seal is a press in affair that takes more force than mere finger pressure, perhaps a tap in affair.
Once the pan is off, I'll be sure to look closely at the seal. If I feel the need to remove it, I'll construct a hook shaped affair out of softer than aluminum polycarbonate to gently work it out.
Appreciate the help.
Thanks again.
Old 12-24-2003, 11:56 AM
jackbrandon jackbrandon is offline
Thanks again.
An appropriately sized socket can be used to press the seal in place
Is it difficult to change tranny fluid and filters on 2002 G.Cherokee laredo? capoeta Grand Cherokee | Grand Cherokee SRT8 3 08-29-2007 01:23 AM
1996 jimmy tranny fluid and filter change bigdawgjr Jimmy 1 06-12-2007 11:00 AM
Changing AUTO tranny fluid 2000 Jetta VR6? Jetta_Y2K '97 - '03 6 03-09-2005 06:18 PM
changing tranny fluid and filter 97 silverbullet Aurora 11 01-02-2004 04:21 PM
