Old 07-13-2005, 09:17 PM
Tonyr's Avatar
Tonyr Tonyr is offline
hesitation
Would a sticky solenoid/valve cuse shifting to be rough or jerky in first and second gear??? This seems to be a problem with our GP's.
Old 07-13-2005, 09:57 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: hesitation
Its possible. The high failure solenoid/valves in the 4T65E tranny are the Pressure Control Solenoid (PCS) and Torque Convertor Control solenoid/valve (TCC-PWM). Also known issues with the valve body.
How many miles are on your GP?
You could try "Lubegard" tranny additive and see if it helps. It also helps drop the tranny temperature.
Thrasher CAI, DHP v1.0 PCM,
3.25 SC pulley, CAIT GMAF, Hi-Flow CAT,
u-bend delete, 160 TS, ZZP Stage 1 TB,
TB spacer, MSD 8.5mm wires, Autolite 104s,
Goodyear Gatorback Serp. & SC Belt,
Nitto NT555R Drag Radials
Timeslip 08/12/06
AF Community Guidelines
Old 07-14-2005, 03:24 PM
Tonyr's Avatar
Re: hesitation
I have a 98 GTP w/85,000 miles. It seems to shift hard or hesitate between 1st and second only.
Old 07-14-2005, 05:57 PM
BNaylor's Avatar
Re: Re: hesitation
There are upshift solenoid/valves. Solenoid "A" controls the hydraulic pressure to 1 -2 and 3 -4 shifts. Its located on the valve body. The solenoids control shift valves inside the valve body which in turn operates the clutches, bands and sprags.
The best thing to do is have the PCM scanned for tranny related DTC error codes.
Timeslip 08/12/06
Old 07-14-2005, 09:13 PM
Tonyr's Avatar
Re: hesitation
Thanks for your help!
Old 07-15-2005, 07:00 AM
troy1 troy1 is offline
AF -Advisor
Re: hesitation
At what RPM does your car hes. Mine does it about 2500 -3000 rpm 1-2 shift only it seems to be worse with the air on. No codes stored. also seems to do it more when the car is warming up, when it gets fully warmed up it goes away.
Old 07-15-2005, 05:07 PM
Tonyr's Avatar
Re: hesitation
Haven't really noticed at what rpm's but it's right at going into second. Mine only does it when the car is warm. If I get going in the morning it doesn't really do it. Seems pretty smooth. It's when it's warmed up it starts acting up.
