Go Back   Automotive Forums Car Chat > Ford > Expedition
Old 07-10-2005, 09:25 AM
maccobra1999 maccobra1999 is offline
obd codes 401&402
my daughter's explorer is showing two codes. po401 egr insufficient flow detected and po402 egr excessive flow detected. help me. where should i start?
Old 07-10-2005, 02:35 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: obd codes 401&402
95% of the time if you get both codes, it is the DPFE sensor. You may want to look at the wiring to be sure the wires are not touching. But, most of the time it is the DPFE.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 09-27-2006, 09:39 PM
chadwic chadwic is offline
I have had some surging and rough running engine the code came back as 402. Would this be the sensor as well? I have gone over the engine compartment vacuum lines and replace most of them.
Thank for any advise
Old 10-14-2006, 08:11 AM
dpfe sensor solved the problem. thanks
Old 10-14-2006, 08:53 PM
way2old's Avatar
TOKEN HILLBILLY
Thanks for fix reply. Appreciate it.
Old 12-11-2006, 10:57 PM
grizz3000 grizz3000 is offline
When I ask for a DPFE sensor the parts guys (AZ, Napa, etc) are baffled.
Is it only a dealer part?
Old 12-13-2006, 08:10 PM
sparkslg sparkslg is offline
DPFE is probably only a dealer part / or the aftermarket parts houses refer to them as something else / EGR sensor ETC .
However it is best to go with factory parts especially DPFE sensors , you will probably get a kit from Ford with a new (different looking) sensor and a new wiring connector
