Old 04-24-2002, 12:41 PM
rendog24's Avatar
rendog24 rendog24 is offline
painting valve cover????????
i was looking around and found this new colored valve cover for my civic and it costs 119.00. well i figured instead of wasting that money i might as well just paint it my self. so just a couple questions before i begin my "project paint". can i just use regular spray paint to color it or is there a "special" paint? has anybody else painted theres.any suggestions.
this is the one i was going to waste my money on.
the red one.
"Don't touch what you can't grab, End up with two backhands, Put anthrax on a tampax, and slap you 'til you can't stand" - Eminem
Old 04-24-2002, 12:52 PM
fjt fjt is offline
Do it yourself... You need heat paint since the Valve cover gets pretty hot. You can use the same paint you use to paint your Calipers, they resist up to 900 degrees and it will do the trick.
Suggestion: Sand the valve cover a lil, put it on the Oven and heat it up before you paint it. Take the V.cover out and paint it while its hot..That way the paint will "Cure" and you prevent the paint from striping away fast.... You can take a sand paper and later polis where the H O N D A letters are to leave them like in the picture you posted.
I heard that if you apply paint stripper to the cover before you paint it, it will leave the cover looking like a mirror, like if you polish it..I dunno if its true though...
Old 04-24-2002, 12:53 PM
JayFidizzy's Avatar
JayFidizzy JayFidizzy is offline
Banned
Send a message via AIM to JayFidizzy
Just out curiosity where did you find those?
Old 04-24-2002, 12:58 PM
fjt fjt is offline
Ha ha youre buying one he he J/K
Old 04-24-2002, 01:13 PM
nw h-town's Avatar
nw h-town nw h-town is offline
Send a message via AIM to nw h-town
OK so like, under my name it does say "newbie".... where can I get the paint for the calipers and/or valve cover? Any hardware store is what I'm thinking but I really have no idea...
Old 04-24-2002, 01:17 PM
fjt fjt is offline
Any Raceshop,Performance Auto store..Even at Pep boys or Western Auto..
If you want it to kind off shine a lil get the one that is Gloss...It leaves a nice shiny finish..Usually you can tell by the color on the Cap...youll see if the cap is "roughy" or gloss like
Old 04-24-2002, 01:18 PM
Protek's Avatar
Protek Protek is offline
Send a message via AIM to Protek
Any Auto parts store should have it. I would get the Duplicolor 1200 degree engine paint.
Make it idiot-proof and someone will make a better idiot.
Caution: I drive like you do.
Old 04-24-2002, 01:43 PM
nw h-town's Avatar
Buennos nachos... much thanks :bandit:
CivicSiRacer's Avatar
CivicSiRacer CivicSiRacer is offline
Civic Mod
Send a message via ICQ to CivicSiRacer Send a message via AIM to CivicSiRacer
I used high temperature primer and VHT Brake caliper paint. on mine and it came out looking stock.
Make sure you use Simple Green or some kinda degreaser. And make sure everything is dry before you paint.
Sponsored by: KAM Racing Sports, Falken Tires, Finish First Polish, Brady's High Performance, Taggart Performance Engineering, Rotora Brakes
Autocross is: 90% driver, 5% car, & 5% CRAZY MOJO!
Autocross Help Page
Buy my Civic parts!
Old 04-24-2002, 02:33 PM
Si2000 Vtec Si2000 Vtec is offline
Send a message via AIM to Si2000 Vtec
When I did mine, I just went over the surface lightly with 400-grit paper, then spray the valve cover down with foam degreaser, wiped it off, then wiped the whole thing down with rubbing alcahol. If you have an air compressor, blow the valve cover off before painting... its pretty common to get unseen stuff in your paint.
Old 04-24-2002, 02:35 PM
almost forgot.... don't forget to plug the holes of the spart plug walls, oil fill, etc. etc. it helps to keep the threads clean and you don't want to run the possibility of paint chipping off into your head. It wouldn't be a big deal, just another precaution to take.
Old 04-24-2002, 04:01 PM
rendog24's Avatar
thanks for all the help. i dont know if i will be putting my valve cover in the oven, but i will definitly be sanding it and rubbing the alcohol and all that good stuff. oh and the valve covers in the picture are from zoommotorsports.com in the brand new section. you can sure save some money by doing it yourself.
Old 04-25-2002, 05:07 AM
kane2g kane2g is offline
Send a message via Yahoo to kane2g
i didnt BAKE the valve cover and its been looking good for last 3 years.
I dont know whats with ppl lately they bake lights and now valvecovers
92 fastback 240sx AKA Ess1Tree Cuz its green, and hasn't moved in months.
Old 04-25-2002, 07:42 AM
Civic Mod
Oh and use Vaseline on the lettering that way you can just scrape it off with a razor.
Autocross Help Page
Buy my Civic parts!
Old 04-25-2002, 08:52 AM
fjt fjt is offline
Kaneg....when you use heat paint you have to cure it, just like when you paint your headers. Now ,not everyone has an industrial oven to do this. You are supposed to paint and then cure but since you are not supposed to put the painted header or valve cover in your house oven due to toxic gases you heat the header or valve cover first unpainted and then apply paint while its hot so you can cure the paint in the process.
You don't know whats up with ppl who do that but that's the right way to do it...
Your valve cover is not like your interior parts that don't heat up and you just paint them and thats it.....If you want it to last a long time you have to cure it.
Painted Valve cover & header shield PIC! bcustom152 Lancer 10 10-24-2002 08:12 AM
Painting Valve Cover MyFirst4G '88 - '91 Civic | CRX | Wagon | Shuttlee 8 08-16-2002 10:49 PM
Painting valve covers... ci5ic '88 - '91 Civic | CRX | Wagon | Shuttlee 12 05-12-2002 04:24 PM
My painted Valve cover.... Whtehnda93DXSdn '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 17 01-09-2002 02:37 PM
