Old 08-15-2002, 09:14 PM
MyFirst4G's Avatar
MyFirst4G MyFirst4G is offline
Send a message via AIM to MyFirst4G
Painting Valve Cover
Hey guys, as most of you gus have said in the last post ( i put up with pics of my car about my valve cover, i got so embarrased that i went out and bought Paint Stripper and RED Engine Paint. I just wanted to know if there is anything special that i have to do. Like should i take the valve cover off the engine? because i have never taken off the valve cover. I can do it, i just wanna know what the best way to do it before i fuk anything up. Yea, and how many coats are good?
88 DX Hatch SOLD!
90 Si Hatch Wreck'd :
Done parting out.. Shell is going to fire dept soon to get roof chopped off for some kind of drill.. wait for the movie!!
96 Saturn SL2:
Daily Driver untill 91DX is running!
91 DX Hatch:
Its gonna be Painted CL Type S Grey w/ WW RS kit from 90 Si and JDM CRX front end conversion... Powered by a Turbo'd GSR Motor..... Loot is on the way!!
Official 4th Gen OG
Hype Race Crew
Old 08-15-2002, 09:30 PM
ci5ic's Avatar
ci5ic ci5ic is offline
worlds tallest midget
Deffinitely remove it from the engine to avoid any overspray.
Once you've used the paint-stripper, go to town on it with a wire brush, then wash it with soapy water and rinse it well. Make sure you mask off any areas you don't want to get paint (bolt-holes, spark plug holes, oil-filler hole, etc.). Then get to spraying. Take your time, use lots of really thin coats to avoid runs and sags. I would probably put on 3 or 4 full coats (multiple thin coats each). Then, use some 320 grit sand paper and sand the paint off of the "H" logo and the other raised lettering on the valve cover.
That should be it. Good luck, send pics!
Old 08-15-2002, 09:33 PM
MyFirst4G's Avatar
thanks man, i will try and do this tommorow, and i will take pics and hopefully set up a how-to section on my page... thanks man!
88 DX Hatch SOLD!
96 Saturn SL2:
91 DX Hatch:
Official 4th Gen OG
Hype Race Crew
Old 08-15-2002, 10:34 PM
FourthGenHatch's Avatar
FourthGenHatch FourthGenHatch is offline
Send a message via AIM to FourthGenHatch
I did mine sort of halfassed. I never knew of the stripper so I partially painted over the old paint.
http://www.fourthgenhatch.com
FOR SALE: Get this stuff out of my house!
-Stock hood (red) $30
-Stock Rear Spoiler (red) $30
-Stock mirrors $30/both
-Stock side front and rear side glass $30/piece
Old 08-16-2002, 07:34 AM
civickiller civickiller is offline
Send a message via AIM to civickiller
hey dont forget you should get a new valve cover gasket since you said you never took it off before. so its probably old and cracking
Old 08-16-2002, 11:19 AM
darolh darolh is offline
If you have access to a sand blaster/bead blaster, that would be the best way to get the paint off and a finish to begin painting. Sometimes you can get it done for real cheap too. If you count the cost of sandpaper and stripper you may not be in it much more by sandblasting.
Paint stripper is nasy shit. I hate the stuff.
Old 08-16-2002, 11:30 AM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
Well its not that hard to paint it. Mine came out really good. I'll to get some pics. I used that engine enamel stuff. I primered and painted. I only used 2 coats. You know the original black rough coating thats on the valve cover. I painted over that cause i like that rough sandy look. Anyways i'll try to get some pics.
Old 08-16-2002, 05:42 PM
ci5ic's Avatar
Or you could just get it powder coated, which is what I'm going to do with my D16Y8 cover. I don't know how much it costs, but a buddy of mine runs a powder-coating shop here in town, so all I gotta do is pick up the powder stuff from Sherwin Williams, and he'll shoot it for free.
Old 08-16-2002, 10:49 PM
1990civic's Avatar
1990civic 1990civic is offline
ive gotten prices on powder coating, and its about 30-40 bucks, which isnt bad, since powder coated valve covers go for about 200 bucks on EBAY!!!!
Painted Valve cover & header shield PIC! bcustom152 Lancer 10 10-24-2002 08:12 AM
Painting valve covers... ci5ic '88 - '91 Civic | CRX | Wagon | Shuttlee 12 05-12-2002 04:24 PM
painting valve cover???????? rendog24 '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 16 04-25-2002 11:41 AM
My painted Valve cover.... Whtehnda93DXSdn '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 17 01-09-2002 02:37 PM
