Go Back   Automotive Forums Car Chat > Honda > Del Sol
Old 07-08-2005, 09:50 PM
ez2plz ez2plz is offline
Lightbulb targa rattle
I have read about and experienced the targa rattle which seems to be a problem with every year Del Sol. Although my 93 Del Sol only has 69,000 miles on it, at times I have a rattle in the targa top. It doesn't bother me much because I know it was indemic to these cars.
I have found out that if I just undo the latch and then re-latch it, that most of the time it goes away. I have read the chapter in the Honda Factory Service manual about adjustments to the roof, but this isn't mentioned.
I think that possibly the reason this might work is because if you have the top off of the car for a couple days or so, the rubber weatherstrip regains its shape. If, then you reinstall the roof it takes a few minutes or possible as long as 30 minutes for the weatherstrip to press together and this could lead to the rattle. By relatching the roof the pins might go in at a better angle or more completly.
Anyway it works for me most of the time. My seals are still very supple and not at all worn. The advice about using 100% silicone to keep them that way is very good. I have owned a lot of older cars and found that the silicone treatment can even bring back some really bad weatherstrip at times.
Old 07-12-2005, 11:35 AM
AudioGuy93DelSol's Avatar
AudioGuy93DelSol AudioGuy93DelSol is offline
NA is Best!
Send a message via AIM to AudioGuy93DelSol
Original Author: Paul Mooney "Peej"
Tools you will need: A deep well 12mm socket and a 12mm open end wrench, ten washers 1/16th - 1/8 in thickness (less than $1.00)
1. REMOVE THE PLASTICS: First, you will need to remove some plastic from your interior & put your top inside your trunk to get it out of the way. The plastic that you will remove will be the sun visor assemblies, A pillar covers, dome light assembly, & roll bar interior plastic. To remove the interior pieces you will need to pry out the little circle behind the sun visor and remove the 4 screws, to remove the A pillar plastic you will need to get your fingers behind the plastic and pull with equally force / evenly on the plastic to unsnap the clips holding it securely to the pillar, to remove the dome light you will need to pry off the clear plastic then remove the screw underneath & then pry out the rest of the assembly, and finally to remove the upper roll bar plastic you will need to pry of this plastic in a similar manner as the A pillar plastic.
2. REMOVE THE BOLTS: You will see 3 bolts in each front corner holding the front roof pin receiver in place, and 1 bolt & 1 nut holding the rear roof pin receiver in place. I suggest that you remove one of these bolts (12mm) and take it down to your local hardware store to get washers that fit (1/1th-1/8th).. Carefully remove the bolts and place the washers between the roof pin receivers and the body of the car. Then replace the bolts and tighten securely. One washer per bolt is enough. We tried 2 and it seemed to help some, but the seals were mashed a little too far and water still seemed to get in.
3. TEST FIT: After all the washers have been put into place try a test fit. You may have to lightly press down on the top to twist the handle and lock the top down. Now with your proper fit of the top & it being satisfactory tightened to the car you can now put your top back in the trunk.
3. FINISHING UP: Replace the plastic on the interior of the of the Sol and enjoy a more water tight top. Don't forget a slightly tighter chassis when your top is in place.
Oil leak? What oil leak? That puddle under the car is just sweat from all that horsepower.
"How many NASCAR passes is that worth? 500?" (Schumacher passing Raikkonen)
Emily is amazing, and she messed with my sig AGAIN!
