Old 07-08-2005, 08:10 AM
denisew's Avatar
denisew denisew is offline
Tranny Problem..please Help!!
Hi,
We bought a used 98 Blazer,2 WD, 4.3 about 4 months ago. It was running fine for a couple months and then the SES light would turn on and off after highway rides, which are not often. Last month it turned on again and stayed on. We scanned it, and it shows the P1870 twice. 1 is now historic. We cleared the codes, and yesterday I took it over to AAMCO,told them what it was doing,(the hard 1-2 shift,then it goes away after the truck cools down,what code we pulled,asked about the TCC solenoid, valve body,etc.) They say it's shifting late in all gears, which I don't feel when I drive it, and that the fluid was burnt and they want to remove the trans and open it for $400. because whatever is wrong with it, is an "internal" problem.
This truck is only a run-to-the-grocery-store truck. It is not driven everyday. Once that light came on, we've only driven it very short distances. Could it have really sustained that much damage in the few months that this SES light showed up? Enough for a rebuild? Beause that's what they were leading up to. AAMCO gave me their quote for a rebuild after a 20 minute once over. $1250. I am starting my search for other tranny shops today, but just wanted your opinion on just how bad this trans could have gotten in such a short time. I am also afraid to get the fluid changed, I've heard that's not a good idea when AAMCO says it's burnt and contaminated. The fluid is a reddish brown. I don't see contamination, but I'm not a tranny expert.
Any opinions? Advice? All is welcome..
Old 07-08-2005, 02:06 PM
Brian_D Brian_D is offline
Not positive about the 98 2WD 4.3L, but the 97 4WD 4.3L employs the 4L60E transmission. The E stands for electronic - shift timing is controlled by the Vehicle Control Module - it supplies GROUND to the appropriate shift solenoid in the transmission. If the transmission shifts through the entire range 1-2, 2-3, 3-OD then the shift solenoids are good.
I would spend the $20-$30 for a new transmission pan gasket and filter, and several quarts of transmission fluid. Drain the transmission fluid and replace the filter myself - care should be taken when reinstalling the filter and/or pan as the internal wiring harness can get crushed causing a permanent short (blown transmission fuse) and a $100+ replacement.
Old 07-08-2005, 02:12 PM
diehlga diehlga is offline
Send a message via Yahoo to diehlga
Re: Tranny Problem..please Help!!
Wow this is exactly what mine is doing. My mechanic did the transmission fluid change etc and the light came back on after running the AC for a while and now it shifts hard. What to do, what to do.
Originally Posted by denisew
Hi,
Old 07-08-2005, 03:21 PM
denisew's Avatar
yes, i see alot of this when i search on here...just wondering if is ok to change fluid if it is contaminated, or will my truck go into a hissy fit.
Old 07-10-2005, 09:57 PM
99church 99church is offline
My 99 was doing the 1-2 hard shift , got new filter, 5 or 6 qts of trans fluid, bought a tcc-pwm (transmission clutch control pulse width modualtor) solenoid.. it is easily accessible after draining fluid and removing pan..
Old 07-27-2005, 09:30 AM
rocky7673 rocky7673 is offline
Hi, my 98 4x4 is doing the exact same and AAMCO wanted 2300 + to rebuild without LOOKING at the fluid or pan. I have it with a good honest guy who will hopefully pinpoint the problem and hopefully its the valve body (which is external) which is what goes bad and causes the problem. My fluid looks good and does not smell. This seems to be a common problem
Old 07-27-2005, 12:26 PM
Allbert Allbert is offline
From what I've read, it is fairly common for one or another of the valves in the valve body to wear and begin leaking (more so when the fluid is warm and thin) and cause loss of pressure which leads to harsh shifts (run through) or slippage that wears the clutches prematurely. I think it is the boost valve that is often the culprit, but the TCC solenoids are also known to be under-engineered. However, for my money, I would almost always try the fresh fluid fresh filter fix (less than $30) before spending the big bucks to let a trans shop rebuild the whole thing or even the valve body. Your chances of fixing anything might only be 1 in 5 or less, but given the difference in expense, I would still take that gamble.
Old 07-27-2005, 12:32 PM
Re: Re: Tranny Problem..please Help!!
By the way, Sonnax makes repair kits for the worn valve issues. If you can pin down the problem to this area and you're a do-it-yourselfer, you can probably repair your own valve body for a lot less than the trans shops. If your fluid isn't showing any signs that the clutches are too far gone already, you might buy a lot of miles for the price of the kit.
Old 08-08-2005, 01:24 PM
denisew's Avatar
anyone have pix or directions on inspecting the tcc while the trans pan is down? i mean, if i'm going thru the trouble of changing out the filter and fluid, which IS a little nasty looking, is there a way to check if the tcc is bad or not? i don't even know where to begin to look for it.
Old 08-08-2005, 01:29 PM
blazee's Avatar
blazee blazee is offline
Problem?
http://www.automotiveforums.com/vbul...d.php?t=440392
Old 08-08-2005, 04:29 PM
97BlazerDude's Avatar
97BlazerDude 97BlazerDude is offline
Changing the fluid and filter is not going to fix this problem (as diehlga points out). Blazee posted a TSB that says a P1870 and a harsh upshift may mean that you need to replace the valve body on the 4L60-E. There is tons of info available on the internet on replacing the valve body vs other potential fixes. In my opinion, they all cost about the same amount (~$150). I looked at all the options and decided to replace the valve body. I will know soon if that worked for me (have only driven to the grocery store once so far - my Blazer is a grocery store truck too - 97 4.3L Blazer). My trans fluid looked brand new. One option I did not look at real hard was the "do-nothing" option. With a grocery-store-truck, that may actually be a viable option - I do not know. It may be the best option if you have low DIY skills and would have a shop do your tranny work for you (may cost ~ $900 for a shop to do a valve body replacement for example).
I can wear a blazer. I can drive a blazer.
Old 08-10-2005, 12:52 AM
i have a 99 blazer, it was doing the hard 1=2 shift, i replaced the tcc-pwm solenoid 27.50 full delivered price. drop pan, drain fluid, solenoid is right there, put in new filter & o ring, new gasket, about 4 qts of new tranny fluid. Solved the problem on our blazer 4l60e
Old 08-13-2005, 08:26 PM
Sunliner Sunliner is offline
My '97 Blazer is doing the same thing....when I drive on the highway for a while, then drop into town, it slams from 1st-2nd from every dead stop. (only does this in the summer though).
What I found was that when it's doing this, I can pull over, turn the ignition off for about 5 seconds, then start back up & it will drive fine.
This led me to believe that the problem is electrical, rather than with the TCC apply valve which apparently is a common problem.
I've read on this forum & elsewhere that the infamous 97 Blazer ignition switch can make the tranny shift hard under conditions like this, so I finally replaced the switch today. took it on the highway for ~40 miles, & got back into town & it's still acting the same way...hard shift 1-2, I can shut down for 5 seconds, & she does great all the way home.
Wonder if the replacing the TCC-PWM solenoid deal would help? I still think it's gotta be an electronic component since it corrects (temporarily) by shutting down for such a short time; I'm guessing if it were a case of the valve overheating/expanding, 5 seconds wouldn't be enough time for it to shrink back.
Hmmmm...
-Mike
For reference:
2006 TrailBlazer LS
I6 2wd
Automatic trans
~72 k miles
I miss my '97 Blazer...
Old 08-13-2005, 09:24 PM
djd99's Avatar
djd99 djd99 is offline
I've had 2 vehicles do this very same thing to me. One was a 97 s10 4x4 with 150,000.. The problem with that truck was it shifted fine for about 15 minutes of driving then it would start to shift real hard.. Pull over let it cool and it would be fine until it heated up again. Second was a 98 S10 blazer with 80,000 miles on it and that truck would slam in second and third gear all the time. I had replaced the valve body on both trucks(Myself) and that fixed both problems. Now even if they rebuilt your transmission without rebuilding your valve body you would end up with the same problem. If this was me I would replace the valve body and put in a new trans filter and fluid. Good Luck
2000 S10Blazer LT 4 Door 4x4
Billet Grille insert
Winter 30X9.5QR15 BFG's All-Terrain T/A KO's
Old 08-14-2005, 04:30 AM
muzzy1maniac's Avatar
muzzy1maniac muzzy1maniac is offline
Is anyone getting codes or lightd from this problem?
2004 Explorer XLT
4.0L 4x4
1998 Ranger Supercab
4x2 3.0L
Anyone who said There Is No Such Thing As A Stupid Question never worked in a grocery store!
Come visit me on www.faceforums.com
