Go Back   Automotive Forums Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 07-07-2005, 02:39 PM
moening moening is offline
93 mustang conv. window motors problem
I got a 93 mustang 5.0 convert. The drivers side rear quarter window stopped working about two years ago, now the passenger side one quit a few months ago. If I push the switch to raise or lower the windows, the battery meter dips some. I unpluged the driver side motor and when I push that switch the battery meter doesn't dip for that side, however, using my multimeter, I can't find any power on that plug. I checked from ground to either wire and across both wires.. I don't see power there, all fuses in the underdash fuse box are good, however the owners manual says that the quarter window fuse is at the starter relay box, but it says that one is for the door locks and sound system too and they work fine.. I'm lost, please give some input.. thanks,
Charles
Old 07-08-2005, 02:17 AM
GTStang's Avatar
GTStang GTStang is offline
Stang Guy
Send a message via AIM to GTStang
Re: 93 mustang conv. window motors problem
Charles
Do you mean when you use the window switch the multimeter detects no volts to the plug that goes to the window motor?
Id so sounds like you have a bad relay and also my guess would be the relay is in the door somewhere. I'd have to look it up cause I have never had power window problems in my Stangs just power door lock issues lol.
Also note that a tired window motor can lead to high amperage and killing relays. So I would replace both while I'm at it.
