Go Back   Automotive Forums Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 07-05-2005, 11:43 PM
IceIceBaby IceIceBaby is offline
1989 5.0 stalling
I have a 1989 mustang 5.0. When it is idleing it is usually around 500 RPMs but now if i don't watch my tach it will gradually go to lower and lower RPMs. It will do this for a couple of minutes and then finally die. It has a new fuel pump and spark plugs. I don't know what the hell it is and it sucks because I can't use my A/C or it will die even quicker. Just wondering if anyone could give me any ideas.....
'89MustangGTConvertible
324rwhp 411rwtq
1/4:73.55secs
Old 07-07-2005, 12:15 PM
Deuce Is Wild Deuce Is Wild is offline
Clean your salt and pepper shakers. Maybe freshen your ignition (not just your plugs) or clean your injectors. What is your voltage at the power supply points from the battery AT the ignition, ECU? Did you check the impedance of the injectors?
Fortunatly if you tried all this, 5.0's are plentiful and you can just go out and get a ECU and try replacing that.
Old 07-08-2005, 02:22 AM
GTStang's Avatar
GTStang GTStang is offline
Stang Guy
Send a message via AIM to GTStang
Re: 1989 5.0 stalling
Let me guess...... did you put in a bigger than stock fuel pump?
Old 07-12-2005, 04:43 PM
Re: Re: 1989 5.0 stalling
I put in a 190LPH when I was still stock and didn't have any problems...
'89 Mustang GT - Edelbrock intake, 75 MM TB, 77 MM MAF, MAC longtube headers, MAC Pro-chamber w/ 2 chamber flowmaster exhaust. Runs 13.5 in the 1/4 spinning like a mofo.
'91 Toyota MR-2 - JDM 3SGTE, 50 trim t3/t4, LSD, SPEC clutch, Apexi'i CAI, 12.4 @ 15 psi, high 11's on the 50 shot.
'97 Ford Explorer Eddie Bauer
'78 Jeep CJ-5 - 401 C.I.D. O||||O
'01 Yamaha YZF600R - Full D&D carbon fiber exhaust, Cam, Factory pro shift kit, front sprocket and miscellaneous other goodies.
Old 07-12-2005, 09:45 PM
williamskinner16 williamskinner16 is offline
clean your IAC Valve
I had a 1991 Explorer, it had a similar problem. Try pulling your IAC valve located ahead of your intake plenum and spray it with injection cleaner or replace it. Im not saying Im sure, but cleaning it might fix the problem. I hope this helps.
Old 07-12-2005, 11:10 PM
GTStang's Avatar
Stang Guy
Re: Re: Re: 1989 5.0 stalling
Not all Stangs 5.0 after minimium 12years in his case 16 year
s are equal.
Understand a 5.0 stock charging system is barely adequate off the assembly line. Add in 12 years and 100,000+miles of wear and tear and it's good chances it has become less than adequate.
So just cause yours was fine doesn't mean his is. Many people have had issues adding a bigger fuel pump cause they draw more current.
Old 07-13-2005, 09:25 PM
Re: Re: Re: Re: 1989 5.0 stalling
s are equal.
Yeah, and my '89 GT had 32 miles on it when I replaced the pump.
