Hi,
I'm looking for any suggestions. etc., for dealing with this issue (the cheapest/easiest way to resolve of course, if possible).
I was recently made aware that my lower brake lights weren't working (rear mount brake light works). I was certain it wasn't the bulbs since they do light up when my lights are on and my turn signals are on (except I have been having trouble with the left trun signal).
Both filaments on all four bulbs work. We checked the brakelight switch and it appeared to be working. Then we put 2+2 together with the brake light/turn signal.
The left turn signal hasn't worked properly for a month so most likely my brake lights have not all this time either (explains some close calls).
The blinker will work if, when I switch it on I also pull it back slightly. Apparently, the brake lights will also come on when I do this.
Ultimately, it looks like I'll have to have the entire turn signal replaced but I'm guessing this involves a lot of work and will cost$$$. And not that I don't mind paying for needed work, but I just had to pay a couple hundred for new front tires and am not sure I can handle an expensive repiar right now.
And I'm nervous because I'll be driving the Mass Pike tomorrow - a couple hundred miles and all I can think to do is, when I apply my brake I can pull in the turn signal at the same time (hopefully, I am coordinated enough to do this). Any other suggestions? Thanks in advance. Pam
