Old 07-01-2005, 11:48 AM
gdawg415 gdawg415 is offline
Unhappy Driver Door is misaligned causing a beeping sound.
Help,
I have a 1995 S-10 Blazer that has a misaligned door which is causing a beeping sound inside. If I slam the door hard enough the beeping will go away but I noticed if I lean against it it will beep. Does anyone know what I need to disconnect so it won't beep. Any suggestions would be appreciated.
Old 07-01-2005, 12:34 PM
cubanlorenzo cubanlorenzo is offline
Send a message via AIM to cubanlorenzo
Re: Driver Door is misaligned causing a beeping sound.
you should fix your door pin and bushings. i had the same problem with my 95 and this fixed it.
http://www.automotiveforums.com/vbulletin/t363334.html
Old 07-03-2005, 03:59 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Also, you must make sure the door plunger on the driver's side of the dash is making contact with the pad it is supposed to press against on the door panel itself.
1995 Factory Blazer Service Manual for sale, PM if interested.
