Go Back   Automotive Forums Car Chat > Toyota > 4Runner/GX470
Old 06-25-2005, 07:52 PM
Andru1313 Andru1313 is offline
very odd please help
Ok I got into my 94 4 runner this morning and went to put down the rear window from the inside and it didn't work. So I walked around to roll it down by the key and it worked fine. I then put down my driver window and opened the sunroof. But then when I went to put down the passenger window or the ones in the back they didn't work. So the only windows that work buy the switch are the driver side and the sunroof.
I can put the back window down by the key only. So I checked the fuses in the engine compartment they looked ok. Also behind the glove box and under the driver side. Everthing looked ok.
Does anyone have any suggestions as to where I can look next. Everything else seems to be working fine. Any help would be great thanks.
Old 06-25-2005, 08:03 PM
Never mind. I am a complete Jackassssss.... After ripping the whole car apart and checking every wire, relay, ground, ect....... It was just that silly little square button on the master control. BINGO. sorry to have wasted you reading time. It is always something simple.
Old 06-25-2005, 08:36 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: very odd please help
Welcome to the AF!
Too bad that you figured it out by yourself, I wanted to look good by giving you the solution...
It will only look bad if you post this problem again.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
