Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > Engine
Engine intakes, exhaust, turbos, nitrous.
Old 04-19-2002, 07:09 PM
Teqp Teqp is offline
Question O2 Sensor
Does anyone know how to check if the O2 sensor is working properly? I have a 93.5 G20 with 115,000 miles and notice a rotten egg smell. The catalytic converter is probably bad, but I want to know why it went bad. I have heard that if the O2 sensor is bad, it could cause the fuel mixture to be rich and have the excess fuel burn in the converter.
If anyone can provide some insight, I would appreciate it.
Thanks.:smoker:
Old 04-19-2002, 08:19 PM
boingo82's Avatar
boingo82 boingo82 is offline
Can't polish a turd.
If your o2 sensor is out, (and you have two, BTW), your check engine light will come on. I replaced mine on Saturday. Do it yourself. It takes 5 mins but the dealers will charge you for 1.5 hrs.
Old 04-20-2002, 12:37 AM
A380Driver A380Driver is offline
Send a message via AIM to A380Driver
Hmm i think the 91-93.5 have only 1 o2 sensor....
-Brian Jones
I got a snake man
Old 04-20-2002, 12:41 AM
boingo82's Avatar
94 has two and that's all I know.
Old 04-20-2002, 03:27 AM
Now a good question is:
What kind of o2 sensor will you use to replace it? Nissan, bosch, NKG, something else? Prices...good product...etc?
-Brian Jones
I got a snake man
Old 04-20-2002, 07:36 AM
On the 93.5, there is only 1 O2 sensor. I know that 95 and above have a second sensor on the the catalytic converter. boing82 said that 94 have a second sensor as well.
So, if I have only one sensor, will the check engine light still come? It hasn't.
If it is not the O2 sensor that is bad and causing my catalytic converter to go bad.
Does anyone have any ideas as to what elso could be going bad?
A local mechanic wants to charge me $70 to run a diagnostic on the car. I would like to avoid this and hopefully do it myself.
Thanks again.
Old 04-20-2002, 08:23 AM
G-ealousy's Avatar
G-ealousy G-ealousy is offline
What kind?
Me personally, when it comes to things like sensors, replacement parts in general, I like going with Nissan parts.... I mean, they made the car for cryin out loud! ha ha!
Old 04-22-2002, 07:31 PM
boingo82's Avatar
I put on Bosch...they make good parts and it cost me $70..not the $133 the stealership was going to charge.
Old 06-18-2003, 05:02 PM
stoneweed1 stoneweed1 is offline
Bosch O2 sensor
any problems with the bosch O2 sensor that you installed?
Old 06-18-2003, 05:42 PM
boingo82's Avatar
It's been over a year now, no probs so far. Car runs great.
Just because offense is offered, does not mean you have to take it.
Old 10-25-2003, 06:44 PM
ImportFool ImportFool is offline
Send a message via AIM to ImportFool
Re: O2 Sensor
Thanks.:smoker:
"I have heard that if the O2 sensor is bad, it could cause the fuel mixture to be rich and have the excess fuel burn in the converter."
the excess fuel is supposed to be burned in the catalytic converter, that is the point, to reduce pollution...what u heard is right, when it fails, it can or will make the fuel mixture rich meaning...the air/fuel ratio is lower than 14.7...
-ImportFool
Old 12-20-2004, 07:33 PM
blue4917 blue4917 is offline
Send a message via Yahoo to blue4917
Re: O2 Sensor
ihave the same problem with the bad smell and the cat is non existent where do i get an o2 sensor and how do i fit it thanks
my car is 94 primera eGT and im from the uk
Old 08-14-2005, 07:16 PM
J..M's Avatar
J..M J..M is offline
Re: Re: O2 Sensor
have it emmisions tested 1st ....... might be nothing wrong with the sensor
Cat is none exsistant ? ....... choo mean ?
Old 09-30-2005, 04:17 PM
nissantech nissantech is offline
Emission testing may not tell you if the sensor is faulty. this is due to the catalyst will remove most of the unburnt fuel. the best way to test is to take it to a nissan dealer to check with consult. or if you are any good with cars, you should have voltage at the sensor connector. live12v/ earth 0v/ and a switch wire. the switch wire should switch between 0 volts to a max of 1.1 volts (atleat 5 times within 10-20 seconds with car running) the lower the voltage the richer the fuel mixture. so 0 volts would be rich and 1.1 volts lean.
hope that helped
I live with fear all week, and at weekends SHE lets me go racing.
Old 04-04-2006, 01:07 PM
p10gtsal p10gtsal is offline
p10egt performance problems
my engine cuts out at 6000 rpm and im missing a good 1250rpm in all gears, also how can you differentiate a gt engine from an SRI cos it could be that??, any suggestions??? UKbased
04 po193 fuel rail sensor woodyh61 Explorer | Explorer Sport Trac 0 02-11-2011 07:13 PM
o2 sensor danielgast46 F Series 0 03-15-2009 09:39 PM
Replacing Evap. canister Control Valve, Boost Sensor, and Knock Sensor? raja Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 16 06-04-2007 03:25 AM
