| Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines. |
can any1 tell me how to get the emblems off the truck without messin up the paint ?
Use a hair drier to heat them. Gently pull them off after they get hot.
Need a dash - http://host21.ipowerweb.com/~internet/ 2002 Maxima, 14.77 @ 97.5 mph on G tech My web - http://xs-fx.com/raughammer/larrysample.htm |
ok, i got the emblems off but the glue wont come off so easy, ive tried wd40, goo gone, and anything else i could think of, how you get the glue off easier?
There are several companies like Meguiars and Mothers that make a product that uses clay as part of their cleaning. I used this with excellent results.
95 Maxima SE (All mods done myself) Check out my website @ http://www.maximacar.com Performance Mods Stillen Intake, Y-Pipe, B-Pipe, Rear Section, FSTB, RSB and Camber Plates Limited Slip Diff (from I30 auto) GC Coil Overs Fiber Images Carbon Fiber Hood Stereo Mods: Concept, Sony, Orion, Eclipse and lots of Dynamat Xtreme |
You probably won't beleive when i say this but you might want to try pait thinner, and a rough rag, that is what i used when i removed the pinstriping off my maxima. It did not damage the paint or the gloss at all. Trust me on this one, but i used a mineral pait thinner, it's not as strong so you will have to let it sit for just a few seconds and then use your finger nails the rub off the glue. :silly2:
@--<---<--- In my race agaist time I...Keep runnin through the red light... |
if you want that glue part off, use a clay bar take the glue out in no time and give you an awesome shiny smooth surface as well. or you can just go to autozone and buy a bottle of adhesive remover for like 3.50 |
what i used
I used boiling water and just poured a bunch on to get off the emblem then poured somemore and picked off the glue with my hand, it clumped off really nicely for me. Then i cleaned it up with some rubbing compound, after i washed my car and covered the hole from behind of course.
try usin a hair dryer to heat it up and then some bug n tar remover to get the stickiness off. thats what i used to take off my pinstripe and it worked perfect. Just be sure to wash and wax the bug n tar afterwords.
:smoker2: |
GET CAR POLISH......like some NuFinish and just let it sit on there for 10 minutes. Wipe it off and then do it again until its clean, very easy and even helps your paint =)
I was wondering before I take the emblems off my car, are there going to be holes where they were? If there are, what Do I fill it with what do i do.
~Leigha~
you can shave the whole back there is no wholes
Are you positive there are not going to be any holes. Someone up there said they used something to fill a hole after they took the emblems off.
-Leigha
they have a 2000 maxima, thats a different body style.
I just did this the other day along with my pinstripes. all you have to do is use a heat gun about six inches away from the emblems and heat untill the glue is warm. use some floss of fishing line and saw behing the emblems they should pop right off. Then heat up the glue a little bit and it should ball up and come right off. Then use some goof-off to get off the residue. then wash and wax and walla.
