Old 06-19-2005, 12:15 PM
iammykehawk iammykehawk is offline
back seat speakers
whats the best way to genew speakers with a screw on grill will that work or do i have to take out the side pannelst the speakers out in the back seatsi was thinkning about getting a box cutting knife and cuting the gril out and unscrewing the speakering and placing my
Old 06-19-2005, 01:36 PM
1986Z28's Avatar
1986Z28 1986Z28 is offline
Has a Camaro
Send a message via MSN to 1986Z28
translation?
Formerly Blownalcoholboy
1986 Z28, 400ci SBC, Twin borg warner billet S467 turbos, Reid case powerglide, Moser 9". Holley EFI, Boost Leash. 950RWHP on pump gas, 1200rwhp on race gas (22 psi)
Best ET 1/4: 8.35 @ 170mph (275 drag radial)
Best ET 1/8: 5.44 @ 132mph (275 drag radial)
Best 60': 1.31 on the back tires (275 drag radial)
AF User Rules/Guidelines
http://www.automotiveforums.com/vbul...uidelines.html
Old 06-19-2005, 02:53 PM
Cammygyrl Cammygyrl is offline
Send a message via AIM to Cammygyrl Send a message via Yahoo to Cammygyrl
Re: back seat speakers
Originally Posted by blownalcoholboy
translation?
lmfao!!!
Old 06-19-2005, 03:11 PM
philly rs's Avatar
philly rs philly rs is offline
Send a message via Yahoo to philly rs
what are u asking, if u clear this question up ill be able to help u, i have done speaker work on camaros.
Your import sounds like my ass after a night of mexican food..
And spraying aint cheating, its brining a gun to a knife fight!!
yeah, its a v6 RS...never mind the f1 badges lol
HYPSI87 u will be missed
Old 06-19-2005, 06:44 PM
89IROC&RS's Avatar
89IROC&RS 89IROC&RS is offline
are you asking how to modify the sail panels on the rear speakers so that you can see the speakers? The way im doing it is as follows. I pulled the cloth off of the cardboard panel, installed the speaker and then installed the carboard panel over it. then used an exacto knife to cut it to the correct size so that you can still install the screws throught the panel and the top screws of the speaker. then recover the panel in the right color fabric. Then install it as follows. you will need six screws for the intall. Install the speaker grill to the sale panel with two screws through the lower two screw holes. then install the sail panel over the speaker which is also held in by the lower two bolt holes. then use the remaining two screws to go all the way through the speaker grill, sail panel, and top two screw holes on the speaker itself. this should be the answer to what i think youre asking.
although i stress that measurements and fitting is critical to makeing this work. so doubble and tripple check everything before you start doing anything permanent. Also, i found it was usefull to get a second pair of sail panels to do my preliminary test fittings on so i didnt ruin my originals.
Chevrolet Camaro - I enjoy beating the hell out of people
http://www.automotiveforums.com/vbulletin/showthread.php?t=68052
