Go Back   Automotive Forums Car Chat > Toyota > 4Runner/GX470
Old 06-17-2005, 04:19 AM
garagemonkey garagemonkey is offline
Question 4runner body on pick up frame
I was just wondering if anyone has ever stuck a 4runner body on a pickup frame.I have an 86 4x4 single cab.Any info is appreciated.
thanks
Old 06-17-2005, 10:35 AM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: 4runner body on pick up frame
I have been under the assumption that the '86 4Runner is just a covered pick-up truck with an independent front suspension. '84 and '85 models were just modified pick-ups...
http://www.top4runners.com/ja/runhist1.html
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 06-20-2005, 10:01 AM
fourwd1's Avatar
fourwd1 fourwd1 is offline
AF -Advisor
1st gen Runners (SFA or IFS) use the standard-cab short-bed frame. Rear body mounts are slightly different and the fuel tank is mounted 2" lower.
Xtra-cab and long-bed models share the same longer wb frame.
All combinations of body and frame swaps are very common, even between generations.
A friend I wheel with started with a std cab, rolled it and swapped on a 4Runner body, rolled it and put on a xtra cab, rolled it numerous times (full int cage), now it's a buggy.
I have a 2nd gen 2WD std cab/shrt bed on my 1st gen 4WD long bed frame.
Anything is possible.
84 4Runner - ARBed 5.29s F&R, 4.7 & 2.28 t-cases, Chevys, AP x-over, BudBuilt x-member, 2" drv trn lift, 36" TSLs, 30 spline Longs
80 something p/u - Buick 231 V6/TH-350 trans, Holley 4 bbl, Weiand intake, dual batts, dual tanks ...
89 4Runner - stock
2000 Isuzu Trooper + 2010 Sonata
