Go Back   Automotive Forums Car Chat > Ford > Mustang > Performance
Performance Discuss Engine, Suspension, Drivetrain, and all other performance modifications here.
Old 06-12-2005, 10:26 PM
StangNut86 StangNut86 is offline
Send a message via AIM to StangNut86 Send a message via Yahoo to StangNut86
Heads
haven't posted on here in a while....
my question is thus: 393 Windsor, stock block, scat crank and rods, probe pistons. I want to run the trick flow twisted wedge type r heads and r-series intake. i've been told that there are problems with the canted valve design in that the angle the intake pushrods operate at causes them to wear excessively on the guideplates. opinions?
also... how long will this combination survive with a mains girdle, 1/4 block fill, and a lifter valley girdle, spinning to 7 grand? not looking for a definite answer.. just opinions. looking at about 600 horse, including spray.
-Andy
'89 Mustang 5.0 - How fast? i'll know this weekend.
'86 Mustang LX - Shortblock is built, now for the rest of it.
"Put the subject before the verb, hmm? Fail this class, you will."
-Yoda teaches english class.
Old 06-13-2005, 05:23 PM
SkylineUSA's Avatar
SkylineUSA SkylineUSA is offline
Send a message via AIM to SkylineUSA
Re: Heads
Its not the guideplates, its the valve guides that wear out. Yes, the geometry is very harsh, but effective. Poor design to a point, great design to a point.
R32 GTR w/351w .020 forged, 8.9:1, PTK T76, Turbosmart 40 BC & 45 WG, Tial 40 BV, AFR 205s 310/245, 228/228 550/550 114 Hydro, 1.7rr, Isky RLs, 4" HKS exhaust, ARC 30x16x4 IC, 8 point cage, C2 gauges, 2 step, C4 3200 stall w/ R Manual & Hurst Ratchet shifter, 17" Panasport G7s, CSU 750 & bonnet, Vic Jr intake, 3.63 gears, Corbeau Carrera seats, Custom wide body, Bomex side skirts and rear 1/4 caps, Tommy Kaira bumper.
Old 06-13-2005, 07:57 PM
Re: Re: Heads
with this stroke at 6500 or 7000 rpm, the stock block with go out of shape long before the valve guides. so i don't think that'll be an issue.
-Andy
Old 06-14-2005, 03:13 PM
SkylineUSA's Avatar
Re: Heads
That is a lot of revs for that engine. You might not even have to go 6500, power band wise?
Old 06-14-2005, 10:20 PM
351wStang's Avatar
351wStang 351wStang is offline
Re: Heads
How much n20 are you planning on? Say a 150 shot for ex. that leaves you needing avg. 450rwhp. You wont have to spin a 393 to 7 grand to hit that number. 6500 at a most I would say. All depends on your heads/cam/intake..for the most part.
1969 Cougar
357w & TKO - 475hp
Old 06-14-2005, 11:16 PM
Re: Heads
after plugging away at the numbers in desktop dyno, i may have a senario where i can spin maybe 6 grand and make lots of power. looking at about 480 horse or so with no spray.... i may leave it at that and not spray at all... i'd like this bottom end to survive, not die with the block. same for the heads and intake. besides, 480 horse with the right trans and gear will do low 12s all day long.... plenty good enough for the bracket racing i do.
-Andy
Old 06-15-2005, 12:26 AM
SkylineUSA's Avatar
Re: Heads
Remember what RPMs stand for
Ruins People's Motors
Old 06-15-2005, 12:28 AM
SkylineUSA's Avatar
Re: Heads
Don't buy a valley gridle, biggest waste on money I have ever seen come out for an engine in long time.
Old 06-15-2005, 08:14 AM
SVTcobra306's Avatar
SVTcobra306 SVTcobra306 is offline
Re: Heads
Get a '69-'71 block, you won't be likely break it with what you're looking for.
I would avoid the block filling. Why build something just to have cooling problems? There are better options, namely a sportsman block. It'll live at 600 and then some.
Get on the horn with some companies like DSS or Bennett racing, you will learn a lot about what you can do with a block.
1994 SVT Cobra. 306, Ported GT-40X's, Crane 2031, NX Wet Kit (100 shot for now),TKO 500, TwEECer R/T, and all the bolt-ons.....
http://www.cardomain.com/id/mccobra94
1995 F-150 SC/4X4 351W/E4OD, K&N, Custom Exhaust w/Flowmaster.
Freedom Isn't Free.
Old 06-15-2005, 10:39 AM
GTStang's Avatar
GTStang GTStang is offline
Stang Guy
Send a message via AIM to GTStang
The problem TFS had wit valve guides wearing out was due to the geometry and I'm positive that was something that they corrected a couple years ago.
Spinning your 351W over 6,500rpm is a bad idea unless you got all the right parts including a light wieght rotating asembly.
I also agree a lifter valley is useless and ignore that article in 5.0 or MM&FF about it.
Also a main girdle is only good to hold the internals in when you crack the mains don't count on any strength added there. But since you got expensive internals I would use one.
The only significantly stronger 351W block is a 69 with it's thicker main webbing, think 351W sportsman block thickness w/o the 4-bolt mains though...
If you keep it at or below 600hp you'll prob be ok cause a stock 351W usually last here but you could also bust yours cause not all are cast equal.
Old 06-15-2005, 12:13 PM
Re: Heads
I was under the impression that the '69-71 windsor blocks all had the higher nickel iron? That's what all the circle-trackers look for back home...Maybe I'm wrong..
Freedom Isn't Free.
Old 06-17-2005, 12:12 PM
boosted331 boosted331 is offline
You're shooting for 450 HP on motor with a 393 and TFS-R heads? 2 or 3 years ago we had a friends street/strip motor on the dyno, it was an FRPP block with good internals, 11:1 compression, 230/244-ish low lash solid roller, vic jr., 850? holley, 2" headers, with accesories hooked up it made ~570 HP and ~550 torque on an engine dyno. That motor's still running with hundreds of track passes on it, in a 3200 pound notch he runs a 10.4 dial in and it's consistent.
A 480 HP 393 in a 3000 pound notch should do upper 10's all day long. Maybe bottom 12's in a heavy ass lightning, but i'll go way faster than 12's in a well setup car.
