Old 06-12-2005, 09:32 PM
nocturnaleclipse nocturnaleclipse is offline
PLZZ HELP ME RUNNING OUT OF TIMe
i just bought a reagular switch from kragen and i have something that has a red wire and a black and red wire NOW how do i up the switch to the wires and get power out of it???
PLZ TELL ME CAR SHOW COMING UP I HAVE NO TIME!!!!
Old 06-12-2005, 09:56 PM
Johannes Johannes is offline
Banned
Re: PLZZ HELP ME RUNNING OUT OF TIMe
It sounds like you need the run the black and red (negative) wire to a ground, which should mean bolting the metal end of the wire to a clean, metal surface somewhere in your car. The red (positive) wire should go to the positive terminal of your battery. You can put the switch on this red positive wire. So, the red wire will come from whatever accessory you're hooking up, onto one terminal of the switch, and then off of the other terminal of the switch and straight to the positive power source. Depending on what you're hooking up, you may need to fuse it as well.
Hope this helps.
Old 06-13-2005, 11:29 PM
curtis73's Avatar
curtis73 curtis73 is offline
Professional Ninja Killer
Positive power source through a fuse to one terminal of the switch.
From the other terminal of the switch to the light.
From the light to a ground source like a screw into the metal somewhere.
Dragging people kicking and screaming into the enlightenment.
Old 06-15-2005, 02:27 AM
thanks guyz
