Old 06-12-2005, 03:15 AM
Hanster24 Hanster24 is offline
Send a message via AIM to Hanster24
car problem again
hey, i think my clutch is going bad
the car shifted "by it self" out of reverse and 1st.
1st and 2nd gears sound fine, when i go into 3d, i start hearing this nois that sounds like ... i dont know.. but its a nois, it gets higher pich in 4, then higher in 5th, if i press the clutch it goes away, it i leave it in a gear (3,4,5) and take my foot off the gas, it will fade out "about 2-3 sec". Sometimes, when im going in revers, the gear doesnt go in all the time, i have to take my foot off the clutch, and try again, and try one more time, then it works, it also does it in 1st. I have to have the clucth ALL THE WAY DOWN, and i do mean all the way down, to shift! is that normal, today i head a " crackling noise after i was at a light, i was stoped and i kinda touched the gas a lill bit, and all i hear is this crackling noise as if smthing was loose inside like that heatsheild thing, i think my clutch is going, one more thing, if i go up to 4k rpms and try to move, like whith the clutch pressed in, "rev first, then apply the clutch" the car will move about an inch, and the rpms will fly, so im gussing thats my clutch slipping, now i didt do that on purpose but, i was pissed from the gf.
any ideas?
96 gst spyder 5 speed
turboxs bov
black in/out + leather
sony speakers + headunit
Old 06-12-2005, 11:23 AM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
First thing: Put your car in your signature. No one is gonna help you until they know what year and model you are driving, and any major mods to help you diagnose the problem. Without this, it makes it much more difficult to narrow down.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 06-13-2005, 12:28 AM
that would make sence
their
turboxs bov
Old 06-13-2005, 12:35 AM
Re: that would make sence
Originally Posted by Hanster24
their
^^I think you meant "there".
'92 3000gt SL
Zoom Stage 1 Clutch
Old 06-14-2005, 02:59 PM
it shifted out again, when i was pulling out of the gas station, and taking a right turn out of 1st gear, it idles at 200 rpms and wants to stop, if i turn it off and turn it on right a way, same problem, i have to wait about 5 - 10 min....
between neutral and 2nd gear, i hear this little grinding nois, its real low, but i can feel some of it two when my hand is on the gear, ....
i just got a recharge kit for my k&n air filter....maby that will fix the idle when its hot out problem, and maby i have bad syncros..i dont know, i need help...im about to take it to the dealer, but i just want to hear some opinions first,....it seems like most of my problems and when im turning
turboxs bov
Old 06-15-2005, 02:50 AM
crazzyguydj's Avatar
crazzyguydj crazzyguydj is offline
Send a message via AIM to crazzyguydj
Re: car problem again
I'm no clutch expert but that sounds like a new clutch. Also this should be in the problem diagnosis sub-forum.
My first car! blue 93 plymouth laser 5 speed <Wrecked!>
My second car! red 93 mitsubishi eclipse 5 speed
3rd car (soon to be) Golf tdi 03 or 04 havent found one yet
Old 06-15-2005, 04:51 AM
fiberglasscivic's Avatar
fiberglasscivic fiberglasscivic is offline
Send a message via AIM to fiberglasscivic Send a message via Yahoo to fiberglasscivic
That sounds like more than a clutch problem to me. You may want to consider the fact that you may need a new tranny. If your clutch was the only problem you had then you wouldn't have the problem with with your gears popping out all on their own. The dealership sounds like a good idea to me. The only thing that I can think of right off the top of my head is that you may be having a problem with the collar which is what connects the gear to the driveshaft connected to the differential. If that for some reason wasn't making a clean connection to the gear then the excess stress of turning could force it off the gear. Here's a simple diagram of what a simple transmission looks like
and here's what a more complicated transmission looks like
There's Flash interactive diagram at http://auto.howstuffworks.com/transmission5.htm
AF COMMUNITY GUIDELINES
Old 06-15-2005, 03:50 PM
diagnoses
k, i took my car to mitsobitchi, and they said that the Idle Air Control Valve is bad. and i have a couple bad berings in the tranny
turboxs bov
Old 06-20-2005, 08:54 PM
i my engine is done!!!!!!!!
on saturday, i parked my car to go to work, i came out 8 hours later, i turn it on, it shook realley bad, i heard knocking and more knocking and then it turn off and didnt turn on again, when i hade it on the tow truck, my muffler tip was filled with carbon, i mean FILLED THICK FILLED
i took it to my mechanic....the spark plugs are dented from the pistons hitting them, a.... and i have no compression
i need an engine.. i found one for $1500.00 after shipping w/ no more than 35,000 miles with turbo and intercoller, alternator, etc...
turboxs bov
