Go Back   Automotive Forums Car Chat > Ford > Ranger | Courier
Old 06-10-2005, 07:58 PM
markymark123 markymark123 is offline
abs messed up
I changed wheel studs on 96 Ford Ranger with 4 wheel abs. Now the abs comes on sometimes for no reason at all. Any ideas?
Old 06-10-2005, 08:44 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: abs messed up
Pull the wheel and check the sensor and tone ring on the wheel you replaced the studs on. Look for bent tone ring, debris between the sensor and tone ring.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 06-11-2005, 05:51 AM
Re: Re: abs messed up
Will grease build up on the ring cause that? Is there special cleaner for the sensor or is brake clean good enough?
Old 06-11-2005, 05:23 PM
way2old's Avatar
TOKEN HILLBILLY
Re: abs messed up
Brake cleaner and a small brush will work fine.
Old 06-11-2005, 05:36 PM
Thank you, way2old. I appreciate the help
