View Poll Results: should i get the Fosgate 501S amp or not
yes 0 0%
no 0 0%
Voters: 0. You may not vote on this poll
Old 04-12-2004, 04:48 PM
97mntecrlo 97mntecrlo is offline
Question what does (2 ohm + 2 ohm) mean for subs?
When i looked at some alpine tyre - R subs that im going to power with a rockford fosgate 501s 2 ch amp, i noticed that they said that their impedance was (2 ohm + 2 ohm) does that mean that my amp is only going to put out what 4 ohm ratings are? Does it matter if i wire it in parallel or not? I know it sounds stupid but I am buying the amp from a friend and if it is only going to put out what the 4 ohm rating is than i dont want it but if it puts out its 2 ohm rating then i do. So i need to know! Bad! Any suggestions are helpful!
Old 04-12-2004, 07:41 PM
sr20de4evr's Avatar
sr20de4evr sr20de4evr is offline
Re: what does (2 ohm + 2 ohm) mean for subs?
that means it has a dual 2ohm voice coil setup, and it can only be wired to 1ohm or 4ohm
1ohm - that amp will hate you and it will eventually die, if it even works at all
4ohm - it will put out the power that it's rated at for a 4ohm speaker
'01 Black Sentra SE
Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers
Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8
'05 Silver WRX STi
Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials
