| Engineering/ Technical Ask technical questions about cars. Do you know how a car engine works? |
Few technical questions
Hello Experts
Plz help me understand the following... a. What is compression ratio? Does it refer to the pressure generated by the piston's upward movement towards the spark plug or the pressure generated after the spark plug has ignited the fuel and air mixture? b. Why is the compression stroke appear constant in most of the vehicles like 9.1:1 or 10:1 etc? Can this be changed? c. Can a four stroke engine be rebored as a 2 stroke engine? I'm not sure if it is common why is that so? d. I may sound cranky in this but still...can gears be attached to the crank shaft so that the number of revolution from the piston be increased? Which will inturn cause more torque or increase the overall revolution including the gearboxes? PS - I may sound silly on few of my thoughts because I'm not formally educated automotive. Thanks in Advance Regards Ganesh .R |
Re: Few technical questions
welcome to the forum.
a) compression ratio is how much the volume of each cylinder is compressed. Example, if you had a 1 liter displacement per cylinder, and after compression it was down to 0.1 liters, you would have a 10:1 compression ratio. B) I don't really understand what you're asking. In order to change your compression ratio, you would have to somehow alter your piston's stroke length, or change the displacement of your heads, ect. C) I'm not sure you understand what a 4 stroke and 2 stroke engine is. Read this - it will allow you to undestand the differences between the 2 engines: http://science.howstuffworks.com/two-stroke1.htm D) I'm not sure what you're asking. Could you be more specific? |
Compression ratio is the volume from bottom dead center divided by the volume at top dead center (when the piston is at the very bottom and the very top)
Compression ratio can be changed by altering one of these two things, either increasing the stroke and keeping the same head volume or deminishing the head volume. higher compression will give you more power, torque and higher revs but if you increase it too much and don't use higher octane fuel, you may get detonation and bye bye engine. I'm sure it's possible to modify a 4 stroke to be a 2 stroke but it would be extremely difficult. but why would you want to do it, you will get more power but much less fuel economy and a smaller availability of parts. you don't need to do this, you can swap out your gears in your transmission. just for simplicity sake, think of you transmission as the back gears on a bike without the middle gears(the ones right at your feet) if you just swap out those gears for smaller ones you get a higher top speed, more fuel economy but decreased acceleration. on the other hand, if you make them bigger, you get more acceleration but less top speed. plus you can get a new rear end (for rear wheel drive cars) that has a different gear ratio to bump up acceleration. hope i helped, if you're confused, just ask me to clarify. |
![]() Quote:
Dragging people kicking and screaming into the enlightenment. |
Re: Re: Few technical questions
Hello Friends
Thanks for the clarification. Can you explain little more in increasing the compression ratio? What may be the pros and cons of increasing/decreasing it? I'm very sorry that I completely messed my question on reboring. A two stroke engine can be rebored so that the cylinder head becomes slightly bigger insize due to which the piston size also needs to be changed. This reboring may be done after 100,000 Kms or so depending on the scratches on the cylinder head (commonly called as engine seize here in India). When doing this sometimes, we do something called porting (not sure what this is) but the outcome is the engine gets more power subsequently reducing the mileage. Well here is what I intended to ask...Can a 4 stroke engine be also... a. Rebored just like the above mentioned 2 stroke engine? b. Ported like above? Thank you very much Ganesh .R |
Re: Re: Re: Few technical questions
Your question was valid.
b. yes, you can port either one and the theory is the same for both styles of engine. The bigger the port, the more air/fuel can get in there, and therefore more power. The only difference is where the port is located; in the head for a 4 stroke and in the block for 2 stroke.
Thank you very much. That helps me understand the complications involved in compressions & doubts about porting and reboring 4 strokes.
I've a question on multipl cylinder engines. Plz let me know if I can post it here or I will start a new thread. Here is the question... Lets take an example of a 4 cylinder engine (be it inline or V shape). I lately came to know that the pistons will be at different stages and each connecting rod will rotate the crank shaft at different point in time. At no point of time all four will rotate the crank shaft (which I was thinking). Based on the above here are my questions... a. For this type of engine, I guess, the maximum speed of all the 4 connecting rod will be the same. So how does increasing the number of cylinders will increase the speed of vehicle or is this just my assumption that increasing the number of cylinders will increase the speed of vehicle (assuming all other factors remain the same like weight of car, # of passengers etc). b. Why is that the engines are designed in such a way that all four connecting rods rotate the crank shaft at different point in time rather than all of them rotating at one time? c. I think (or assume), if all 4 connecting rods rotate the crank shaft at one point in time the load on the engine is distributed to all 4. Plz correct me if I'd posted something incorrectly or have not phrased my questions correctly. I will be happy to rephrase my question if anything is inclear. TIA Ganesh .R |
![]() Quote:
![]() Quote:
I was going to say the same thing but add something for the adding cylenders. When you add more cylenders it makes the engine run smoother. I think this helps with resistances or something so that it allows the engine to rev higher. Formula one uses V10 engines (they're being cut down to 8 next season) that only displace 3 litres. the extra cylenders i think help it to rev higher (up to 15,000rpm, let's see that out of a civic)
I am confused...........If you had the 1L to 0.1L cylinder bored such that it displaced 1.1L would it not compress to 0.11L (or something close) ?? I realize the top of the cylinder is not flat topped but I seem to feel that The larger bore would cause a larger volume when compressed than the original bore. Set me straight. (I know I am missing something...I just don't know what) |
You are right in practice. For the sake of simplicity in the demonstration I was assuming a flat top piston at zero deck and actually no clearance to the head. In practice there is more combustion space than just the chamber, but the math is tougher
Hello Experts
Thanks. -------------------------------------------------- Increasing the number of cylinders is a way of increasing engine displacement (among other things). Its just that there are certain points at which designing more or fewer cylinders makes sense. For instance in large commercial trucks which need a lot of engine displacement, a four cylinder doesn't make sense. The cylinders would have to be so big that the pistons would be very heavy, and the vibrations the engine would put out would not be pleasing. In a small car, a four cylinder makes sense as a way of maximizing displacement in a small area. -------------------------------------------------- I'm sorry that I'm unable to understand completely on the above. Could you please enlighten me more on the above? -------------------------------------------------- Two main reasons: 1) so that the force from one piston can move the other three through their other strokes. If they all fired at once, the engine would only operate at a speed fast enough that its inertia would carry it through all four strokes. However, this does occur in one-cylinder, 4 stroke engines. Since there is only one cylinder, it has to use inertia to carry it through. Because of this they have a narrower range of applications. 2) because of #1, mostly for the sake of smoothness. An engine with all of its rotating weight moving in the same direction would cause pretty violent shaking. Not only would it make you angry, it would shorten the life of the engine -------------------------------------------------- So if I understand right, if all 4/6 connecting rod tries to work on the crank shaft at the same time, then, the inertia would try to break one of the component like crank shaft or connection rod or sometimes the piston itself. Am I right? TIA Ganesh .R |
Current Car: 1997 Pontiac Sunfire GT Automatic with 17'' American Racing Sniper Wheels And GM tires.(They took my Pirelli Tires off when I bought it ) The hardest thing to learn about cars is that they aren't that hard to learn. Current Projects: Finding the RPM Between Safety and Thrill 300-400 hp midrange '95 Honda Civic Rally Car.(Project starts in 6 months. Wish me luck . )
Ok Thanks. I think I'm getting it. It would take sometime for me to understand.
I know there is a relationship between the cylinder chamber (including piston, crankshaft, connecting rod) and the RPM. But I cannot visualize it. Could you please help me relating them. TIA Ganesh .R |
As far as their power production is concerned, that is more of a function of the other components that make up the engine.
