Old 05-29-2005, 12:10 PM
aarganesh aarganesh is offline
Question on Hydrogen Engine
Hello Experts
I read something about using hydrogen as fuel in an internal combustion engine. Here is what it meant...
1. The diagram looks like a normal combustion chamber except that the spark plug is replaced with low heating coil.
2. It's a cylinder that intakes air and pressurize the air. Then pump in hydrogen (in the ratio of 180:1 something like that).
3. Now the coil sends out small spark which creates enormous heat. This heat is now preserved using some techniques.
After this nothing else has been mentioned. I'm not sure if this could work. I assume this could work as there are few strokes involved in this suction, compression, power and exhaust. My questions are...
a. Will this work?
b. If this works, what would be the output? Is it the heat? If yes, then how the heat is used to generate torque?
Plz help me understand this.
Thanks in Advance
Ganesh .R
Old 05-29-2005, 05:50 PM
sierrap615 sierrap615 is offline
Master Tech Wanna-be
Re: Question on Hydrogen Engine
you know i had a real good link on this subject, think i can find it? no.
anyway yes it does work, it is identical to a standard gasoline powered 4-stoke engine, only difference is hydrogen is the fuel, not gas, i haven't heard of the spark plugs being replaced though.
in fact, water is the source of the hydrogen. water (H2O) is spilt into hydrogen and oxygen, then injected into the engine as fuel.
the idea dates back to at least 1935, i did just find this link - http://www.keelynet.com/energy/garrett.htm
as for you second question, heat produces power in all internal combustion engines. the "controled burn" or exposition does not push the piston down. the heat generated by the burning causes the gases in the combustion chamber to expand, the expanding gases is what pushes the piston down.
search for "water fueled cars" and you might be able to find more information. then there are also fuel cell cars, that use water/hydrogen to create electricty, then power an electric motor.
Old 05-30-2005, 08:19 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Hydrogen is a fuel that can be oxidized (burned) in a reciprocating engine like any other such fuel, gasoline, diesel, kerosene, propane, methane etc.
Hydrogen can be used in a fuel cell to create electricity to power an electric car. This is a more efficient use of the gas, since it wastes less energy from creating combustion heat.
Old 05-31-2005, 12:45 AM
hahaha...Thanks folks.
Actually I extracted this information that was published in our local daily. It said that this article was submitted by an automobile student during 2000 or 2001 during his final semester and he had explained this theory. I actually wanted to inquire more on this and thought this is the best place.
So I guess this experiment is not his original idea then.
Thanks folks
Ganesh .R
Old 05-31-2005, 07:42 PM
beef_bourito's Avatar
beef_bourito beef_bourito is offline
I know BMW made a car with an internal combustion hydrogen engine. I have a magazine with it in it and when i get to it ill tell you about it. it's at home so ill have to wait till the weekend to get it (i live at boarding school). i think it hade a prety high power output but i'm not sure.
Old 05-31-2005, 08:08 PM
CBFryman's Avatar
CBFryman CBFryman is offline
Banned
Send a message via AIM to CBFryman Send a message via Yahoo to CBFryman
BMW, GM, Ford, they've all made hydrogen powered vehicles, the problem hydrogen can be very volitile and is very hard to contain and transfer...
Old 06-01-2005, 12:24 AM
Surprising!!!
When was these cars manufactured? Is it in late 90's or after 2000? Where can I find more info on these? On BMW sites???
Has any Japan manufactured any car engines with hydrogen fuel technology? Plz help me find if they have manufactured one.
TIA
Ganesh .R
Old 06-01-2005, 04:13 AM
curtis73's Avatar
curtis73 curtis73 is offline
Professional Ninja Killer
Probably the reason you don't find much information about them is because they haven't found reliable ways of making them in production vehicles. A lot of testing and research has been done, but the auto manufacturers don't publish all of their research until it becomes reliable enough to be something they could actually produce.
The big problems with hydrogen are the excess heat and the violent explosion it creates inside an engine. Once they learn how to handle that, hydrogen might be a viable fuel.
Dragging people kicking and screaming into the enlightenment.
Old 06-01-2005, 09:46 AM
That's true, the BMW I read up on was just a research car. Concidering what a small quantity can do (a beaker full makes a pretty big explosion) It'd be a while before i got inside one. Plus, having a tank full of it might be pretty dangerous. Hydrogen fuel cells seem more viable and a more realistic use for hydrogen. I wouldn't expect to see hydrogen in internal combustion engines any time soon.
Old 06-01-2005, 08:27 PM
Speedsteve Speedsteve is offline
http://www.msnbc.msn.com/id/6089614/
http://www.bmwworld.com/hydrogen/
http://www.bmwzentrum.com/exhibits/hydrogen_car.asp
Old 06-03-2005, 01:33 AM
Pardon me if I sound silly, but this is what came into my mind.
With the technology of chips incorporating into automobiles...
1. We have a chip that has already been programmed on the maximum fuel (hydrogen) is required for a safe combustion probably taking into account of the current gear and RPM etc- Call this chip C1.
2. Lets have another sensor chip sensing the throttle open & closes. Call this chip S1.
3. Lets have another chip that actually mixes the fuel+air and sends to the cylinder - Call this chip C2.
4. So S1 senses and sends to C2 and C2 takes the advice from C1 and then sends to cylinder.
Plz ignore if I'd sound too techno-cranky?
Regards
Ganesh .R
Old 06-03-2005, 08:25 AM
Schister66's Avatar
Schister66 Schister66 is offline
AF -Advisor
Send a message via AIM to Schister66 Send a message via MSN to Schister66
another engine that i read about that runs on hydrogen is the Renesis Rotary engine from Mazda. I did a research paper on it and that engine seemed to work the best because of the 3 chamber design.
2015 DGM STi - 2006 SGM STi - 1999 Built/boosted GSR
Old 06-04-2005, 08:44 AM
Re: Re: Question on Hydrogen Engine
Plz could you kindly explain me more technical details on this?
TIA
Ganesh .R
Old 06-04-2005, 08:47 AM
Regards
Ganesh .R
Any comments? Curtis?
Old 06-04-2005, 05:42 PM
i don't know where the technology is at in the india auto market, but overhere in the states, as well as in japan and europe, we have been using a setup like that for decades, we call it Electronic Fuel Injection. where there is a computer(commonly called the Powertrain control module or Electronic control module) that uses sensors to measure amount of intake air, throttle position, engine speed, vehicle speed, and engine tempature, as well as a feedback oxygen sensor in the exhaust. the computer then takes that information and compares it to "fuel maps" that are programmed into the computer's memory, and then controls the amount of fuel delivered using electionic fuel injectiors(which are basicly just PWM solenoids)
is that what you are thinking about? then all you would need to do is alter the fuel maps for hydrogen instead of gasoline, and use special fuel injectiors i assume.
