Old 05-23-2005, 08:55 PM
LoW_KeY's Avatar
LoW_KeY LoW_KeY is offline
slipping with 3.0 pulley?
Just curious when they really start to slip? seems like it pulls fine in 1st, 2nd and slips a bit in 3rd then grabs. Yes I'm using a manual, not the auto.
If it is by chance slip I was thinking about go with a no slip 2.8/3.0 pulley if the injectors allow it.
http://www.southfloridapulleyhq.com/...lip_system.htm
I could've sworn once you hit 3.0 slippage could occur, thanks!!
3800 SC/IC Fiero some say I whine more then my car...
Old 05-23-2005, 09:34 PM
kustomkid54's Avatar
kustomkid54 kustomkid54 is offline
Re: slipping with 3.0 pulley?
I would say that if it was going to slip, it would do it from 1st to second. High "R"'s would cause it faster.
Smaller pulley? How many mods are the running. 3.4" is about it for stock motor.
Good luck.
Old 05-23-2005, 09:50 PM
LoW_KeY's Avatar
well I don't really rip on on it often think I noticed it a bit in 2nd with the higher RPM's but the tires were breaking loose at 55-60.
mods are
ZZP IC 3.0 pulley
headers/exhaust
1.8 rockers/ls6 valve springs
160 tstat/autolite 103's
ECM/CAI
think that covers it, if it matters. I might just invest in it and call it good maybe drop down to a 2.8 no slip while I'm at it, what the hey.
Old 05-23-2005, 10:13 PM
Re: Re: slipping with 3.0 pulley?
mods are
ZZP IC 3.0 pulley
headers/exhaust
ECM/CAI
Tried a couple smaller pulleys. Went back to the 3.4".
Had the same trouble with my car. 45 MPH it would brake lose. Went to some ZR rated tires. Took care of most of that.
Let us know how you make out.
Old 05-25-2005, 10:39 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: Re: Re: slipping with 3.0 pulley?
That South Florida Pulley company is great. Excellent products and tech support. Their interchangeable and no slip pulleys are the best around.
It's probably better to consult with them since you plan on getting pretty radical on the pulley size. What brand SC belt are you running?
Like Jim (KustomKid54) I'd be interested to know how it turns out. Good luck!
Thrasher CAI, DHP v1.0 ECU, Granatelli CAI Tuneable MAF,
3.4 SC pulley, Hi-Flow CAT, u-bend delete, 180 TS, TB spacer,
MSD 8.5mm wires, AC Delco 41-932 spark plugs
ET: 14.3 @ 96 mph
Timeslip 08/12/06
AF Community Guidelines
Old 05-25-2005, 11:30 AM
LoW_KeY's Avatar
running a gatorback right now, the belt could be rather old. I bought the IC used and it came with a belt and it fit believe it or not
