Old 05-23-2005, 06:11 PM
stage1 stage1 is offline
BigL or GTP Dad please help
97 gt 3800 Afew weeks ago i started hearing a click coming from the direction of the fuse box and the radio and clock shut off. Afew seconds later it will click again and they will come back on. this happens while driving, idling whether car is hot or cold. Doesnt happen every trip or day. The radio and clock was all i noticed at first (dash lights stay on head lights stay on) but then i noticed that when its making the clicking noise that i lose power to the windows and over head lights. It doesnt have any SES or any other lights coming on. where should i start or what to do any help would ba appreciated.
Old 05-23-2005, 07:00 PM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: BigL or GTP Dad please help
I have checked every wiring diagram I can find on the Grand Prix and cannot find a circuit breaker anywhere in the circuits you mentioned except one for the power windows. It sounds like there is a relay or circuit breaker tripping in the system somewhere and then resetting itself. You may want to check you fuse block and see if a fuse has been replace with a breaker or relay. I really can't find any other reason that this would be happening unless one of the grounds is loose and then is making contact and the click you hear is the transfer of voltage. Good Luck! Maybe Big-L will have some better ideas.
Old 05-23-2005, 07:40 PM
kustomkid54's Avatar
kustomkid54 kustomkid54 is offline
Re: Re: BigL or GTP Dad please help
Dad,
Doesn't the radio(and clock) have a timer on it, so when you turn the car off, it won't run down the battery? When that goes off it clicks.
Had radio diagram around here someplace. Will look for it and send it to you.
Old 05-23-2005, 07:51 PM
Dad,
Here's what I have on the 1997 Radio. You may have to blow them up.
Jim
Old 05-23-2005, 08:36 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Hey what's up Jim (KustomKid54). Whats the story on Big-L? Guys a great information source but I see you're doing a great job filling in. Don't you just hate electrical problems on these things.....lol.
Found an interesting graphic for you. I see you're doing a good job evading and alluding the internet police. BTW - We hit 105 degrees today. Later.
Thrasher CAI, DHP v1.0 ECU, Granatelli CAI Tuneable MAF,
3.4 SC pulley, Hi-Flow CAT, u-bend delete, 180 TS, TB spacer
ET: 14.3 @ 96 mph
Timeslip 08/12/06
AF Community Guidelines
Old 05-23-2005, 08:50 PM
Re: Re: Re: BigL or GTP Dad please help
ET: 14.3 @ 96 mph
Have a feeling that the cops will be hot. Read last post.
Emailed Big-L 3 or 4 times. Don't know. Maybe his computer died. Or he doesn't like us anymore.
Saved Taz. He will return someday.
Old 05-24-2005, 05:29 AM
Pontiac Guy
You are correct but I think the timer is in the power circuit that controls both the interior lights and the radio. I will recheck my book when I get home this evening to see if I can find where it is located and where it is wired. I can see the common wiring on this diagram but it does not actually tell where the timer is located. The diagram just isn't clear enough for me to see. Obviously it is malfunctioning causing everything to turn on and off.
Old 05-24-2005, 07:42 AM
PM your email address. I will send you the PDF file. That wat you can blow it up.
By the way, did your computer stick?
Old 05-24-2005, 05:57 PM
Pontiac Guy
Yes my computer would not send the post and I stopped it the computer reposted it three times. The radio circuit does not power the timer as it must be a part of the BCM. I can't find one on the wiring diagram for the 97 model but if the car was produced in late 97 there is a possibility that the car has one. The wiring diagram for the 98's shows one clearly. Look to see if the BCM is present and if it is changing it or checking the connections may correct the problem.
Old 05-24-2005, 06:21 PM
Dad,
I think bnaylor3400 may have the answer.
I'll let him responed to this himself.
Dinner time
Old 05-24-2005, 09:41 PM
BNaylor's Avatar
Originally Posted by kustomkid54
Dad,
Dinner time
Thanks for the kudos Jim but it looks like you guys are doing a great job on this one. First off, I hate throwing in my 2 cents on electrical problems of this nature. Don't know how technical the person needing help is and their capability. Too many variables.
I do agree 100% that it is most likely a BCM (Body Control Module) related problem. Under the dash to the left hand (driver's) side are two modules. I'm not sure about a pre 1997.5 GP GT. One has relays and a circuit board. The relay the guy hears klicking is on one of these. The only work or experience I have on one of the modules is disabling the daytime running lights (DRL) on a 2001 GP GT and that was 2 years ago. BTW - It's pretty hard to troubleshoot in that area, especially since you'll be laying on your back and looking up. Like GTP Dad suggested the connectors would be a good starting point. Unless he gets lucky by replacing one of the modules, he'll need schematics and a digital multimeter for more in depth troubleshooting, if necessary.
All I can say otherwise is good luck!
3.4 SC pulley, Hi-Flow CAT, u-bend delete, 180 TS, TB spacer,
MSD 8.5mm wires, AC Delco 41-932 spark plugs
ET: 14.3 @ 96 mph
Timeslip 08/12/06
Old 05-24-2005, 10:06 PM
PM sent
Old 05-25-2005, 10:23 AM
BNaylor's Avatar
Here's a pic of the original 1997 GP GT BCM (Body Control Module). The AC Delco part numbers are 10427830, 10427831, 10439803 depending on keyless entry options, etc. GM recommends ID by the original part number on the BCM.
Hope the info helps.
ET: 14.3 @ 96 mph
Timeslip 08/12/06
Old 05-25-2005, 08:34 PM
i thank all of ya'll so much for trying to help im lost on electrical stuff and was hoping it would but a quick fix lol guess not so i guess ill have to take it to0 a pro thanks again oh also the noise is coming from under the glove box area thanks again
Old 05-26-2005, 05:19 AM
Pontiac Guy
Let us know what they find out when you get the verdict from the mechanic.
