Old 05-16-2005, 06:24 PM
ReCKleZ ReCKleZ is offline
turn signals are blinking fast
hello, the turn signals of my 2002 firebird recently started acting up. my turn signal lights were working fine but all of a sudden they started blinking fast, then they go back to normal and then they start blinking fast again. im not sure what the problem might be but any help is appreciated. thanks in advance!
Frank
Old 05-16-2005, 07:48 PM
blindeyed's Avatar
blindeyed blindeyed is offline
eBay aDdict™
Send a message via AIM to blindeyed
Re: turn signals are blinking fast
Frank
From what I've heard, when your signals start blinking fast, that means the bulb is about to burn out. I may be wrong. But that's what a friend of mine told me.
- Jason
1995 Pontiac Firebird
User Guidelines | VB Codes Explained | AF Merchandise
"Each of us, is in the scheme of things, insignificant.
But millions of insignificant people, doing a tiny bit,
can add up to be a very significant force."
Old 05-17-2005, 07:08 AM
volkerc's Avatar
volkerc volkerc is offline
Frank
bllinxeyed is correct.check all your turn signals, one might not be working. could be because of a defective bulb or corrosion on the contacts.
Old 05-17-2005, 10:20 AM
its kinda weird. when the car is off and i just have the key turned so i can hear the radio and i turn on the turn signals they work just fine. but when i have the engine on it starts doing that. both turn bulbs are working. any other suggestions?
Old 05-17-2005, 12:15 PM
LT1MAN LT1MAN is offline
Banned
they're about to blow
Old 05-17-2005, 09:16 PM
Philo Philo is offline
Have you replaced the flasher unit? I am not an electrical whiz, but with the engine off, it is possible that less voltage is available to the flasher than when the alternator is supplying current (engine running). If the flasher unit is weak (getting ready to fail), it would seem to work properly when the battery is powering the electrical stuff, but could be overloaded when the alternator is supplying the power.
Old 05-27-2005, 10:11 PM
tri-power's Avatar
tri-power tri-power is offline
I agree. I have experienced similar situations with my various pontiacs over the years to have bad flashers when it happens. Seeing how it's a relatively inexpensive part, changing it wouldn't hurt reguardless.
Old 05-27-2005, 10:29 PM
Daniel Doerksen's Avatar
Daniel Doerksen Daniel Doerksen is offline
from my experience when blinkers pace are quickened its because the fuse is blown
Old 05-28-2005, 12:15 AM
Matt365's Avatar
Matt365 Matt365 is offline
Send a message via AIM to Matt365
i am also having problems with my turn signals, but only the left one. Sometimes it works, sometimes it doesnt. When it doesnt work, the green arrows jus sits there and stays on... and im like wtf do something, but it doesnt.
Old 05-28-2005, 02:29 AM
not fuse problem then..
Old 05-28-2005, 01:23 PM
tri-power's Avatar
That does sound like either a bad bulb or maybe even a bad ground.
Old 05-28-2005, 04:29 PM
JCbabe4585 JCbabe4585 is offline
Send a message via AIM to JCbabe4585
Lightbulb
My 2001 Firebirds turn signals were acting up too one time...they would go really slow and then all the sudden speed up. I ended up just changing the Flasher plug and now it works fine. Hopefully this helps you. :-)
Old 06-13-2005, 01:21 PM
whats a flasher unit?
what is the flasher unit and where can i find it in the firebird.
Old 06-13-2005, 03:08 PM
tri-power's Avatar
Right Of Steering Column, Mounted To Bottom Of
Instrument Panel Carrier
