| Latest | 0 Rplys |
#1 | |
over the last few days now i turn the key to start nothing happens car wont start but all ignition lights come on as normal then it has started to turn over slightly and cut out again and also i have noticed the red service light flickering on and off quickly when i see this i know when i go to turn key that nothing will happen but if the red light stays red the car will start ok.also sometimes i can hear a slight buzzing noise coming from passenger side like its coming from fuse box area.
last night "14 may" the car wouldn't turn over enough to start it just kept cutting out as if starter was sticking this was happening for about ten minutes so embarassing outside a shop so evenually to get iut saarted i put it into reverse and turned the key while in gear and away she went. this doesn't happen all the time but i dont want it getting any worse. |
#2 | |
Re: 1.5 dci wont start
Hi,
Did you manage to get it sorted? I have the same problem...the diesel light won't go off and it won't start, then I leave it for 5 mins or so then it starts! I've taken it to the garage and they've replaced and cleaned injector leads and cleaned the corroded lead points but still the same! Thanks |
