Go Back   Automotive Forums Car Chat > Mercury > Mystique
Old 05-15-2005, 12:56 AM
hunter01 hunter01 is offline
warped dashboard cover
Hi all. A friend has a 2000 mystique and the front edge of the dashboard cover where it meets the defroster vent is curled back all the way across the dash so that the edge of it is pointing straight up. Also the defroster vent cover is disconnected from the dash and is just sitting there loose. Has anyone had this problem, what causes it and can it be fixed without replacing the dash. Thanks in advance for any help.
Old 05-15-2005, 09:19 AM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
there was a recall on this.
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
Old 05-15-2005, 10:08 AM
Re: warped dashboard cover
Does this mean that the dealer has to fix it for free? The car is 6 years old. Where do I find a copy of the recall.
Old 03-09-2006, 06:01 PM
greeffs greeffs is offline
my 2000 mystique has the same problem and I called my dealer who says that they do not not know of any recall . What is the word on the street.??
Old 03-13-2006, 09:55 PM
brandon200317 brandon200317 is offline
http://www.automotiveforums.com/vbul...d.php?t=515555
i posted the same issue in ford contour forum here... there's the link just above... it wasn't exactly a recall, i forgot what they called it, but it's in the other forum... it was an issue they had with late 99 and 2000 mystiques and i believe contours too.
Black 01 silverado LT z71. 5.3L extended cab.
Black 2000 Mercury Mystique LS, 2.5 v6 5 speed.
