Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 04-11-2002, 12:30 PM
XxEL DuKexX XxEL DuKexX is offline
thudding springs
I have had my Eibach Pro kit springs on my 98 max for 2 months now & everytime I make a moderate turns I hear a thudding noise especially from left front of car, i still have stock 16" wheels & struts (i know you are not supposed to have stock struts w/ lowering spring), i cant think of what could be causing it, has anyone had this same problem with lowering springs?
Old 04-12-2002, 01:19 AM
funnylittlman funnylittlman is offline
Send a message via AIM to funnylittlman
Question off of your question
Hey,
I am thinking about getting the H&R Sport Spring set for my 99 max, do you think that I can run into the same problem, if I keep the same stock struts and shocks. I know of people who haven't had any problem, and when I talked to a rep at the Tire Rack, he said that it shouldn't be a problem. On think that you might to check is the actual shock... it could be bad. Also my buddy suggesed that you check your bushings, they could be bad? Hope that helps, and I hope you can help me out! Thanks
99 Max SE Limited
APEX'i Cat Back Exhaust
PIAA Super Whites
Clear Diamond Cut Bumpers
Cleared Rear Corners
H&R Sport Springs
KYB AGX Adjustable Struts & Mounts
Old 04-12-2002, 05:37 PM
fixed
I got a chance to put my car up on the lift at work & take a look at it, there is a stud that stops the steering wheel from burning up the power steering pump when you fully turn, its located underneath the tie rod end, just crack loose the locking nut (19mm) and turn the end with a 17mm about half inch(not to much or you will burn your P.S. pump when you do U-turns), the reason it was making that noise is since the end of the stud has a rubber end and the car being lowered it changed the position when it would touch the subframe, thus making te rubbing noise during turns.
Old 04-15-2002, 10:10 AM
NJMAXSELTD NJMAXSELTD is offline
Re: Question off of your question
Originally posted by funnylittlman
Hey,
Don't put sport springs on your OEM struts. It doesnt ride right. I did it, learned my lesson the hard way. The force sport springs put out can't be controlled properly with OEM struts. Get some aftermarket bangers like KYB's or Tokico's. I hear that Tokico now has an adjustable out for our cars.
99 SE LIMITED - A few changes here and there but most of all SPOTLESS!
Old 04-15-2002, 01:57 PM
MaxRX7's Avatar
MaxRX7 MaxRX7 is offline
the thudding would be coming from your shocks.
you need some good aftermarket ones.
also Sprint springs are better and cheaper.
Maxima parts for sale:
http://home.comcast.net/~luisrx7/MaximaParts.htm
Old 04-16-2002, 02:07 AM
Unhappy
So I guess I should go for the whole shabang. How much would that run me?
99 Max SE Limited
PIAA Super Whites
H&R Sport Springs
Old 04-16-2002, 11:36 AM
MaxRX7's Avatar
I've seen the Sprints go for $120, and
the AGXs for $370.
all 4
$500 and the maxima will handle awesome, like you would never imagine it could and look tight with the drop.
Springs Made in Canada springman West Canada 0 12-01-2010 04:14 PM
XJ Rear Leaf Spring Swap Problems Jim Aldrich Cherokee 1 04-04-2010 09:25 PM
Lowering Spring HELP! sentoyang Brakes and Suspension 2 10-23-2009 05:34 PM
Prizm 2001 LSi Suspension Coil Springs genti Prism 0 04-16-2009 02:48 PM
Detachable Spring under front seat adamchrissy Type 1 1 03-14-2009 10:58 PM
